297 Users Online (16 Members):
- Most ever was 712 - Sat, Aug 8, 2026 at 7:11:41 PM |
Forums >> General Discussion >> Revit Project Management >> Stairs Depth
Thank you, Going to contact my distributor asap... thank you so much,
Hi DAMAREVIT,
You might have purged everthing. That happened to mine too.
I have working with Revit since 2007, everythinf was fine until a couple month ago, that I lost everything in my template.
I even unable to re-create my template from scratch.
If you got the answer, please share.
Edited on: Fri, Mar 21, 2014 at 10:42:47 PM
@DAMAREVIT Open your stairproperties. The click right of the "Run Type" row. You'll see a grey square with three dots in it.
Click on this square, this opens an new window showing the properties of your "Run Type".
The parameter you need to change is "Structural Depth" (see images attached)
@WWHUB See that wasn't too hard.
Kim - you did not read all of the posts. This user's initial post did not indicate he was using stair by component and I responded as if he were doing stair by sketch and my response for that was correct. He was missing function because he was missing updates. However, I guess I should have looked closer at the images he later posted to see that he was doing stair by component and in that case, the setting is in a different location as you have pointed to. But this setting is ONLY for COMPONENT stairs
For other users - component stairs, read this help topic.
TheRun Component Type Properties
2 sets of stairs, 1 landing, 1 cutback. possible? |
Sun, Mar 1, 2009 at 3:28:10 AM
Line-based DF with array: parameters in nested families need help |
Thu, Oct 17, 2013 at 4:40:34 PM
Plan Region & stairs |
Thu, Jun 18, 2009 at 1:28:36 PM
Railing Joins on Multistory Stairs |
Tue, Feb 17, 2009 at 8:32:15 AM
How to Make random depth dimension in a nested family. |
Thu, Nov 19, 2009 at 8:56:26 PM
Members: | 2165478 | Objects: | 23399 | Forum Posts: | 152370 | Job Listings: | 0 |
