32 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Stairs Depth
Thu, Mar 20, 2014 at 2:51:38 PM | Stairs Depth
DAMAREVIT
I have been trying to to increase the size of a stairs treads depth,
Currently it not pass any code test.
Please provide feedback
Thank you
*Attached image
Thu, Mar 20, 2014 at 3:24:55 PM | Stairs Depth
Edit the type properties - stringer carriage height
Thu, Mar 20, 2014 at 3:30:50 PM | Stairs Depth
DAMAREVIT
I wish i would see that option here in the version i am using (2013), sometimes i really think the other versions are better.
look at the options i have.
Thu, Mar 20, 2014 at 8:40:31 PM | Stairs Depth
mansell5
3.5 Stars: 4 Votes
reduce tread depth to 275mm , see if that makes a difference
Fri, Mar 21, 2014 at 7:08:52 AM | Stairs Depth
DAMAREVIT ....  Come on.... Do you see that slider on the right of your image?   Pull it down!  The settings are below what you show.
Fri, Mar 21, 2014 at 8:33:27 AM | Stairs Depth
DAMAREVIT
Trust me, 225mm never changed anything, I am really wondering what could be the issue.
Fri, Mar 21, 2014 at 8:43:50 AM | Stairs Depth
Read my POSTS!!!!
Fri, Mar 21, 2014 at 9:06:15 AM | Stairs Depth
DAMAREVIT
wwhub, ok let me follow you, I think in 2013 those options are not in the type property box, what I just did was change the stairs type from monolithic to precast, and now the depth as been increase which is good. I still need to figure out how to increase the depth by using the properties box. What version revit you are using?
Fri, Mar 21, 2014 at 9:32:21 AM | Stairs Depth
Balony.... I've been using Revit since 8.1 and I have 11,12,13 and 14 installed now.  Use the slider on the right of the properties box that you posted to slide down.  If the chevron on the right of the blue colored bars points down, click on it to expand that area.
Fri, Mar 21, 2014 at 9:40:43 AM | Stairs Depth
DAMAREVIT
Oh, yes... i did slide it down and all that and all i see was identity  data and those kind of information, could you post an image from within 2013 with the option you telling me to find,
thanks
Fri, Mar 21, 2014 at 9:48:36 AM | Stairs Depth
Here
Fri, Mar 21, 2014 at 9:59:51 AM | Stairs Depth
DAMAREVIT
oh, I see, your system family is stairs while i dont have that feature, something is really going on. atleast I find a work around.
Look at my image
Fri, Mar 21, 2014 at 10:05:33 AM | Stairs Depth
#13
What do you mean you don't have that feature...... You do....ALL STAIRS ARE SYSTEM !  And you can have multiple defined types.  I just pulled up the first one ... I also have the default Monolithic which yours has been renamed as Cast-in-plcae .... ALL THE SAME!
PLEASE-PLEASe-PLEASE pull down and expand the stringer category!
I'm done!
Fri, Mar 21, 2014 at 10:13:06 AM | Stairs Depth
#14
DAMAREVIT
i wish i had a stringer column to pull down, I got none... and thats what I am trying to say.
Fri, Mar 21, 2014 at 10:39:51 AM | Stairs Depth
#15
We have asked all users to include their Revit issue and updates.  This would have been settled long before now if you had done that.  You image shows me you have failed to install your updates..... And every issue has a different number of updates that must be installed in sequence.  2013 has 3.
2012 - Break Line on stairs below View Depth
Mon, Oct 15, 2012 at 4:19:35 AM
How do you alter stairs in revit so that they could have a tread of 9" and riser
Fri, Sep 28, 2012 at 1:27:53 PM
Stairs - Matching Length to Minimum Required Risers...
Wed, Oct 12, 2011 at 10:18:31 AM
Plan Region & stairs
Thu, Jun 18, 2009 at 1:28:36 PM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Page generation time: 4.2271
