174 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Problem with Reigion Hatching on Site Plan
Tue, Feb 25, 2014 at 7:08:33 PM | Problem with Reigion Hatching on Site Plan
#16
tazman1
tazman1 Avatar
No need in both of us being frustrated.  No, there's no warning telling me to check the visibility settings.  I am drawing a region box above the roof of my building on the site plan.  I cannot see the hatched region.  I believe I did what you said.  I turned everything on and even played with the different phasing settings.  Also when I select the region on the revised plan to view the properties, it doesn't give me any information other than that it is there and the scale.
Tue, Feb 25, 2014 at 7:14:18 PM | Problem with Reigion Hatching on Site Plan
#17
tazman1
tazman1 Avatar
Tue, Feb 25, 2014 at 7:27:35 PM | Problem with Reigion Hatching on Site Plan
#18
tazman1
tazman1 Avatar
I found it.  The original site plans were on "realistic view".
Tue, Feb 25, 2014 at 7:28:31 PM | Problem with Reigion Hatching on Site Plan
#19
tazman1
tazman1 Avatar
THANK YOU!!!!
Tue, Feb 25, 2014 at 7:31:07 PM | Problem with Reigion Hatching on Site Plan
#20
tazman1
tazman1 Avatar
Ok.  Why is the callout detail of the accessible parking so much bigger than the callout bubble when I insert it onto a sheet?
Tue, Feb 25, 2014 at 7:34:23 PM | Problem with Reigion Hatching on Site Plan
#21
3.5 Stars: 378 Votes
Your attachment is corrupted.
Your not telling us something.
Do a crossing selection in that plan across the area where you want the hatch.  What all is there?  Have you got some other hatches already?
Did you copy another plan to create this?  Start a new one from scratch and copy paste anything annotative into it.  Maybe this view is corrupted.
Tue, Feb 25, 2014 at 7:52:28 PM | Problem with Reigion Hatching on Site Plan
#22
tazman1
tazman1 Avatar
Hatch problem solved.  Thank You.  I had the drawing on realistic view.
Why is the callout detail twice as big on the sheet as the callout bubble.  This was the second of the two questions I asked in the beginning.
I opened the detail drawing and made the crop region smaller....
Tue, Feb 25, 2014 at 8:36:10 PM | Problem with Reigion Hatching on Site Plan
#23
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
The callout bubble on your site plan is shown at 1-20, but your actual detail that the callout creates is at 1-10 so it is larger which it should be otherwise there is no point in having a callout bubble.
Edited on: Tue, Feb 25, 2014 at 2:40:55 PM
Tue, Feb 25, 2014 at 8:58:24 PM | Problem with Reigion Hatching on Site Plan
#24
tazman1
tazman1 Avatar
How do I change the size of the viewport and the size of the title line from being outside of the titleblock boundaries?  I understand the scale of the drawing being twice as big.  But why all the empty space to the right of the callout?
Tue, Feb 25, 2014 at 9:11:23 PM | Problem with Reigion Hatching on Site Plan
#25
Hello..... can't you see the Project point and the Survey point?  Turn those off in VG.
Tue, Feb 25, 2014 at 9:42:55 PM | Problem with Reigion Hatching on Site Plan
#26
tazman1
tazman1 Avatar
I figured it had something to do with the blue thing.  But never heard of Project Point and Survey Point.
Tue, Feb 25, 2014 at 10:19:15 PM | Problem with Reigion Hatching on Site Plan
#27
tazman1
tazman1 Avatar
Thank You again for your help.
Area Plan Hatching
Fri, Oct 26, 2018 at 3:23:00 PM
hatching line doesn't show in callout views
Thu, Jul 26, 2012 at 12:10:09 PM
invisible road carparks and landscape on site plan
Fri, Aug 28, 2009 at 11:44:33 AM
External wall hatching in Plan View issue
Sun, Feb 7, 2016 at 1:05:27 AM
site plan disappears intermittently
Fri, Mar 17, 2017 at 2:21:12 AM
Page generation time: 19.0245
