408 Users Online (29 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Trouble with Creating a Standard Detail
Thu, Dec 19, 2013 at 10:34:40 AM | Trouble with Creating a Standard Detail
dannidw
I am trying to create a standard detail (in detail view) for import into other drawings.  The detail at this point is a section cut in a project.  I have tried exporting it to CAD and reimporting it into Revit but it keeps freezing up.  Is there another way to do this?
Revit 2013, AutoCAD 2010
Danni D. Waddell
Designer
Tevis Architects
Thu, Dec 19, 2013 at 10:47:07 AM | Trouble with Creating a Standard Detail
3.5 Stars: 405 Votes
As you have found out, model views are not portable between projects.  Your process is correct so I don't know what your problem is.  There is actually an add-on called "Freeze drawing" that performs the same function.  Where is your problem, on import into a drafting view?
Did you open the CAD and look at it?
Before importing the CAD, you should clean the file up like you should on any import.
Thu, Dec 19, 2013 at 10:48:43 AM | Trouble with Creating a Standard Detail
zakazai
i have attended many trainings in revit, but still i have a doubt regarding floor finishing with tiles.
i would like to know, how i can put ceramic tiles in various sizes in a room, may be 2-3 different sizes of tiles comes together. or i may need to cut some patterns on the floor that is filled with marbles, like water jet cut designs.
i know how to add material but i am confused to make it tiles and other designs.
can anybody help
Thu, Dec 19, 2013 at 10:58:11 AM | Trouble with Creating a Standard Detail
dannidw
Yeah, it's when I try to import the CAD into Revit.  I tried cleaning up the file.  I even exploded all the groups in case that was making the file to big, and got rid of the text because I can always add that back in later.  I haven't tried OVERKILL so I'll try that next.    It gets to 42% really fast and then stops.  I got it to 75 % once but then it dropped way back down the next time I tried.
Danni D. Waddell
Designer
Tevis Architects
Thu, Dec 19, 2013 at 11:01:18 AM | Trouble with Creating a Standard Detail
dannidw
Zakazai - I think you made a mistake.  You need to go to the Technical Support forum and ask your question from there.  That way you'll get more answers.  You replied to my question instead, only the people who stop to answer or look at this question will possibly see your question.
Danni D. Waddell
Designer
Tevis Architects
Thu, Dec 19, 2013 at 11:21:51 AM | Trouble with Creating a Standard Detail
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Just a question that I have been askign everyone lately is do you have all of the updates installed for our revit version and autocad?  This sometimes helps with quirky problems.  However you said you tried to keep file size down?  How big is the file that you are trying to import?  It is just lines so it shouldn't be big at all.
Thu, Dec 19, 2013 at 11:33:31 AM | Trouble with Creating a Standard Detail
zakazai
oh , yes Danni.
thank you for your kind advise
Thu, Dec 19, 2013 at 2:08:28 PM | Trouble with Creating a Standard Detail
dannidw
133 KB
Danni D. Waddell
Designer
Tevis Architects
Thu, Dec 19, 2013 at 2:09:51 PM | Trouble with Creating a Standard Detail
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you installed all of the updates??
Thu, Dec 19, 2013 at 3:49:17 PM | Trouble with Creating a Standard Detail
dannidw
I've taken out even more stuff, and it still won't work. What did I wrong.
Where's freeze frame?
Danni D. Waddell
Designer
Tevis Architects
Thu, Dec 19, 2013 at 3:56:53 PM | Trouble with Creating a Standard Detail
#11
I doubt the problem is your file.  If it is so small, post it here and let us try.
You don't answer tefoe's question about updates.  That question would not have been asked if it wasn't important.  Give us how many updates you have installed.
Thu, Dec 19, 2013 at 3:57:46 PM | Trouble with Creating a Standard Detail
#12
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If your not going to answer the questions that we ask you about YOUR problem then it is pointless to try and help you as we can't get anymore information from you.  DID YOU INSTALL ALL OF THE UPDATES???  Freeze Drawing is an ADD-IN that you need to download.
Thu, Dec 19, 2013 at 3:58:09 PM | Trouble with Creating a Standard Detail
#13
dannidw
Danni D. Waddell
Designer
Tevis Architects
Thu, Dec 19, 2013 at 3:59:59 PM | Trouble with Creating a Standard Detail
#14
dannidw
I have no idea about updates.  So I imagine no.  It's my work computer.  I've never had the problem before.  Maybe I'll take it home and try on my laptop.
Danni D. Waddell
Designer
Tevis Architects
Thu, Dec 19, 2013 at 4:03:00 PM | Trouble with Creating a Standard Detail
#15
dannidw
How do you retrieve updates in case that is the problem?
Danni D. Waddell
Designer
Tevis Architects
Detailing in Revit
Fri, Nov 15, 2013 at 10:27:37 AM
Ceiling Model Lines Showing up on Floor Plan
Tue, Dec 13, 2011 at 6:04:04 AM
Repeating Detail Component for Metal Lath
Tue, Apr 1, 2008 at 12:59:06 PM
Creating an Enlarged Detail View of a Detail I have Drawn
Fri, Aug 31, 2012 at 7:05:29 AM
Standard Details [ 1 2 ]
Thu, Dec 19, 2013 at 11:18:44 AM
17
Page generation time: 0.3670
