42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering Modeled Siding
Tue, Sep 11, 2012 at 7:35:46 AM | Rendering Modeled Siding
#16
AbsoluteBIM
AbsoluteBIM Avatar
3.5 Stars: 3 Votes
you've seen a few sheets shots from our material editor... can you show us a shot of your setup for your siding material?
Tue, Sep 11, 2012 at 8:17:32 AM | Rendering Modeled Siding
#17
3.5 Stars: 388 Votes
The siding you are using does not appear to be a ship lap but maybe a T&G.  If you want the havy lined ship lap then you will need to use that material.
Tue, Sep 11, 2012 at 11:24:15 PM | Rendering Modeled Siding
#18
ml22
Warchitect,
I did my best to match Typhoon's settings exactly.  The image I posted was rendered with the "best" rendering quality setting.
Wed, Sep 12, 2012 at 9:16:03 PM | Rendering Modeled Siding
#19
ml22
My siding set up images attached.
Thu, Sep 13, 2012 at 3:43:00 AM | Rendering Modeled Siding
#20
4 Stars: 201 Votes
Increase "Bump" value.
Thu, Sep 13, 2012 at 11:05:23 AM | Rendering Modeled Siding
#21
Warchitect
4 Stars: 5 Votes
ML 22: you jpeg image sample size is set for 1 foot actross 8 boards..that makes each board on the rendering less than 2" wide...board siding is around 6" to 12" for one board...maybe adjust that too
Thu, Sep 13, 2012 at 1:17:24 PM | Rendering Modeled Siding
#22
quinn
Are you using a bump map to contrast the depth further?
Edited on: Thu, Sep 13, 2012 at 1:17:39 PM
Thu, Sep 13, 2012 at 1:33:24 PM | Rendering Modeled Siding
#23
AbsoluteBIM
AbsoluteBIM Avatar
3.5 Stars: 3 Votes
Warchitect has your answer; change your sample size to 4' x 4' and then adjust from there. Just make sure that whatever you do to the material image, you'll have to do the same to the bump image to ensure they match.
Sun, Sep 16, 2012 at 1:44:32 PM | Rendering Modeled Siding
#24
ml22
Warchitect et al.,
I agree that the scale did not seem to be right, but the siding was rendering as 6" boards.  I can't explain why.
I tried increasing the bump value, and I matched the bump and material images, but my result was very bumpy siding.  This is very much a step in the wrong direction, as Hardi-Plank is smooth (OK, textured is available, but I'm not using it).  And the edges of the boards still are not especially visible.
Sun, Sep 16, 2012 at 1:54:10 PM | Rendering Modeled Siding
#25
Warchitect
4 Stars: 5 Votes
maybe try a different Jpeg image. a photo of somthing more regular...sorry our ideas aren't working for you. I feel your pain brother!
Fri, Oct 19, 2012 at 9:25:06 AM | Johnzo142
#26
sllana
5 Stars: 2 Votes
Quoting Johnzo142 from 2012-08-31 16:53:07
Here is the entire image.
Hi Johnzo, please tell us how that roof is made. It's excellent.
Fri, Oct 19, 2012 at 10:00:44 AM | Rendering Modeled Siding
#27
Johnzo142
Thanks. You have to use a sloped glazing roof and create custom mullion profiles.
This post was very helpful for me: http://www.revitcity.com/forums.php?action=viewthread&thread_id=815
rendering horizontal wood siding.
Wed, Aug 5, 2009 at 10:49:00 AM
Showing Horizontal Lap Siding correctly in Rendering
Mon, Jan 23, 2023 at 2:41:29 PM
Looking for source of metal siding rendering patterns.
Thu, Mar 22, 2007 at 7:40:40 PM
Metal siding
Mon, Mar 16, 2009 at 9:44:10 PM
Wall Sweep/Siding
Sun, Feb 17, 2008 at 12:11:00 PM
Page generation time: 0.4076
