Forums >> Revit Building >> Technical Support >> FYI. Stairs showing through floors in REVIT 2013
Thu, Aug 23, 2012 at 9:56:46 PM | FYI. Stairs showing through floors in REVIT 2013
#16
Khuongledinh
Khuongledinh Avatar
1 Stars: 1 Votes
I had tried many time with VG but it still doen't work. The floor isn't hidden. The underplay is only show visible/invisible with opaque things, so it doesn't affect railings and stairs.
I don't believe ability's VG of Revit. Just through the same my stairs and railings. There're two different results with the same setting
110236_Baluster_and_rail.jpg110236_Baluster_and_rail_1.jpg110236_Baluster_and_rail_2.jpg
Fri, Aug 24, 2012 at 7:23:11 AM | FYI. Stairs showing through floors in REVIT 2013
#17
You said there is an underlay - get rid of it.
Fri, Aug 24, 2012 at 8:23:35 AM | FYI. Stairs showing through floors in REVIT 2013
#18
Khuongledinh
Khuongledinh Avatar
1 Stars: 1 Votes
I know the rid of the underlay. But I seldom use it. Anyway, we can get on manually by "hide element/category". And now, I still get trouble with stairs and railings below the floor.
Mon, Jan 6, 2014 at 7:23:03 PM | FYI. Stairs showing through floors in REVIT 2013
#19
Bish
Had similar problem, resolved by switching from Wireframe to Hiddenline view
Wed, Sep 23, 2015 at 2:57:56 AM | FYI. Stairs showing through floors in REVIT 2013
#20
keeza09
I realize this is a long time afterwards, but just wanted to say thanks to Bish. simple solution is sometimes the hardest to think of. this was the issue in my case and i take it from Khuongledinh's silence, that it sorted her issue also.
Attaching stairs to floors
Wed, May 24, 2006 at 11:29:47 PM
Revit 2020 - Stairs not showing in plan levels
Sun, May 29, 2022 at 7:23:51 PM
Stairs in plan
Thu, Sep 27, 2007 at 2:20:16 PM
Floors not being cut in sections in 2013
Fri, Jan 11, 2013 at 8:44:07 AM
Revit Architecture 2008 Multi Level Stairs - Complex Building
Sun, Dec 4, 2011 at 4:39:37 AM
Page generation time: 4.7462
