60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> Revit for interiors
Hi,
I was watching a webcast about revit for interiors, and I was surprised when the presenter linked to a CAD drawings and was clicking on the walls which transformed immediately to 3D! I didn't know we can do that with Revit. I always traced on top of walls to create the revit 3d walls. Here's the link incase anyone is wondering what Am I talking about. http://usa.autodesk.com/adsk/servlet/oc/offer/form?id=18472993&siteID=123112&ch=EM&src=AEMIV&mktvar001=461701&mktvar002=461701
it will ask you to fill out a form to be able to see it (which I don't like) you'll have to redo the form if you closed the window by mistake :s
The thing is that I tried doing that in Revit, but couldn't find out how she did it..how can you create the walls in Revit from a linked CAD dwg. without having to trace over the cad walls the traditional way? Am I missing something? :S
Forgot to mention that I'm using the new Revit building 2013.
47 Posts No Rating |
I did not watch the linked video but I would guess she used the pick line tool.
Edited on: Wed, May 2, 2012 at 4:31:23 PM
Yes she is just using the pick lines tool
If you have a cad plan, it's not a bad way to start, with an underlay... especially for a project like a reno. But it sets a dangerous precedent in offices which are trying to transition from cad to revit. because before you know it, the "official" and "current" plans and elevations remain in .dwg form.
I know dinosaurs that like to do SD in autocad and as they draft their designs I've mocked them up in Revit. They are always blown away that I can recreate their linework into a 3d model in minutes. My secret... If they arent already polylines in cad i convert them, then in the wall command in Revit I select pick line and hover over different areas while pressing Tab until the entire area highlights. BAM!!! instant wall layout.
Yeah that's what she was using. I tried it and it worked. Thank you all
Just remember to lay in some Revit dimensions before you go to far using the CAD file as a base. I find a lot of CAD drawings that are not rally square and thus parallel objects created in this way will not dimension in Revit.
Gray Gloomy Interiors Revit 2010 |
Mon, Aug 9, 2010 at 12:35:46 AM
Splitting Master Model into separate Interiors and Docs Models |
Wed, Aug 21, 2013 at 7:24:50 AM
Interiors specialist & the drywall "cover-up" |
Thu, Jun 11, 2015 at 2:58:03 PM
Sustainable Design Interiors |
Sun, Jan 9, 2011 at 7:34:45 PM
FLOORING FOR INTERIORS (MODEL) |
Fri, Sep 8, 2006 at 2:09:34 PM
Members: | 1986995 | Objects: | 22874 | Forum Posts: | 152184 | Job Listings: | 3 |
