71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Room tag not showing in only one room.
Mon, Mar 31, 2025 at 3:20:06 PM | Mr Spot
#16
garrettg1318
Quoting Mr Spot from 2011-09-15 19:36:16
Hi Rob,
By the sounds of things that particular room is "Hidden by View".  Use the "Reveal hidden elements" (lightbulb) button to turn on everything in the view (should be able to see everything hidden but if its hidden via filter it still won't show).  Select the Room and choose, Unhide element.
HTH.
"Mr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot AvatarMr Spot Avatar
#17
garrettg1318
Hi Rob,
HTH.
#18
garrettg1318
Hi Rob,
HTH.
Mon, Mar 31, 2025 at 3:20:07 PM | Mr Spot
#19
garrettg1318
Hi Rob,
HTH.
#20
garrettg1318
Hi Rob,
HTH.
Mon, Mar 31, 2025 at 3:20:35 PM | Mr Spot
#21
garrettg1318
Hi Rob,
HTH.
#22
garrettg1318
Hi Rob,
HTH.
Mon, Mar 31, 2025 at 3:20:57 PM | Mr Spot
#23
garrettg1318
Hi Rob,
HTH.
#24
garrettg1318
Hi Rob,
HTH.
Sun, Apr 6, 2025 at 9:54:39 AM | Room tag not showing in only one room.
#25
saifkhan
If the room tag isn't showing in just one room, try checking the settings or permissions for that specific room. psl schedule today It could be a display issue or a configuration problem. https://pslschedule2025.com.pk/
Wed, Apr 23, 2025 at 9:51:07 AM | Room tag not showing in only one room.
#26
hvacee
Hi Rob,
Thanks for the detailed explanation — this sounds like a frustrating issue. Based on what you've described, it seems like Revit is having trouble recognizing the room boundary in the plan view, even though the room is enclosed and behaves normally in section. https://windmason.sa/
Thu, May 8, 2025 at 7:42:53 AM | Room tag not showing in only one room.
#27
MaisieOscar
If a room tag isn't showing in just one room Instagram Pro check visibility graphics, annotation crop settings, view filters, or if the room is properly enclosed with room-bounding elements in your mode
Fri, May 9, 2025 at 1:18:00 AM | Room tag not showing in only one room.
#28
Moterieved
Nice info. If you're looking for a fun break, you should definitely check out the Slope Game it's an addictive and fast-paced experience worth trying!
Room not showing
Tue, Mar 25, 2025 at 7:06:37 PM
ROOM TAG TAGS ONLY HALF OF THE ROOM
Wed, May 6, 2015 at 8:58:21 AM
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
Room Data Sheet (inc furniture and doors) using a Room Tag
Fri, Jan 20, 2012 at 9:47:21 AM
Page generation time: 0.6274
