150 Users Online (149 Members):
Forums >> Revit Building >> Technical Support >> Paramters
208 Posts No Rating |
Hi All,
Has anyone created a parameter which returns a list of the opening numbers (Marks) for a particular type mark?
I am trying to create a door tag which returns the following :
Type Mark
Mark (a list of all mark numbers for that door type. Not the total of marks)
Description
cadjockey
Door tags were only created to report the information of the element they're tagging. The mark is an instance parameter and as such cannot be tailored to report all the marks of a particular type by only tagging one door.
Why not just have it show type mark, mark and desciption using tag all not tagged... not really much effort and if a particular type of door is changed it will reflect in the type mark and desciption....?
Hi Mr spot,
I was trying another way of quickly creating a traditional door schedule. Without having the spreadsheet.
I was hoping to create a custom tag that when applied to a set of doors I am using to create the door image within the door schedule drawing sheet, would return the doors type mark, description and all the mark numbers(opening numbers) that door type has been used in.
I could then pull an elevation of all the door types I have set in a sample wal and tag all not tagged using this custom tag. I would limply drop the view into my door schedule drawing sheet.
Having said this I personally do not have a problem using the spreadsheet to one side on the door schedule drawing sheet. It's the traditionalists I am working with that have the challenge.
cadjockey
Yes/No paramter controlled by two different types of paramters |
Thu, Mar 13, 2014 at 11:58:39 AM
Titleblock Labels (Custom to each sheet) |
Thu, Jul 3, 2014 at 4:16:30 PM
Families |
Wed, Aug 1, 2012 at 10:30:38 AM
Scheduling Revit MEP Panel name and circuits |
Fri, Nov 11, 2011 at 9:45:29 AM
Newbie needs some advise on where to start |
Wed, Aug 10, 2011 at 3:42:19 PM
Members: | 1988942 | Objects: | 22877 | Forum Posts: | 152179 | Job Listings: | 3 |
