197 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
Search this ThreadSearch this Thread | Page 2 of 3 | << Previous 1 | 2 | 3 Next >>
Thu, Dec 2, 2010 at 9:51:44 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#16
crwinchester
crwinchester Avatar
3.5 Stars: 4 Votes
I'm not sure if you mentioned this already, but you also have an option in the properties bar to change the color scheme location to either foreground or background.
Thu, Dec 2, 2010 at 9:57:34 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#17
suedehart
suedehart Avatar
Yes - the color scheme is supposed to be in the background, but I believe it's not reading properly as a result of the upgrade from 2010 to 2011.
Thu, Dec 2, 2010 at 11:01:29 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#18
crwinchester
crwinchester Avatar
3.5 Stars: 4 Votes
Another thing that I encountered today with this issue was offset limit of the room area itself was taller than the floor to floor and the visibility was overlapping a bit. I set mine to be the limit of ceiling and it behaved correctly in the instance I was working in. Not sure if this is applicable to you or if you've already done that as well.
Thu, Dec 2, 2010 at 11:12:41 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#19
suedehart
suedehart Avatar
That was a really good thought that I hadn't tried, but unfortunately did not prove to be my problem.  If I set the room height lower than my cut plane the color doesn't show up at all, and if it's higher than the cut plane, my doors disappear.
Fri, Dec 3, 2010 at 3:40:12 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#20
crwinchester
crwinchester Avatar
3.5 Stars: 4 Votes
Two things: Does the visibility of the doors change at all levels of zoom? Mine tends to have a display glitch like this where my doors temporarily disappear depending on how far or near I'm zoomed in. Have you tried to print a test of the view to pdf to see if it persists? I would still investigate some of the geometry itself and make sure theres nothing weird in the families (though you said they were out of the box doors) or if there are any offsets or gaps between floor walls etc. I guess I would also try manually drawing the room boundaries to see if there is still an issue. Very strange.
Fri, Dec 3, 2010 at 4:27:21 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#21
suedehart
suedehart Avatar
That's exactly what is happening to me - it appears to be a display glitch, but the most annoying part is that when we print, the plans look the way they do on the screen.  I'm going to try to start a fresh file and see if that makes a difference.
Fri, Dec 3, 2010 at 7:11:01 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#22
dgcad
dgcad Avatar
3.5 Stars: 34 Votes
Maybe try inserting a new 2011 door with the same name and types as the old one and overright the previous door(s) completely with a new OTB 2011 door.
For the most part, do a saveas of the project and then try replacing the doors with OTB 2011 doors and see if that helps.
Try playing with the scale factor, detail level and Visual Style of the view.
Check Pen Weights, Object Styles and Line Styles in the family and in the project.
Upgrading projects in REVIT from one version to the next is not always seemless.
Fri, Dec 17, 2010 at 3:28:08 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#23
suedehart
suedehart Avatar
Thanks to everyone who's replied on this - just as an update, I started a new project in 2011 and had the same problem.  So much for that theory...
Fri, Dec 17, 2010 at 8:10:51 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#24
dgcad
dgcad Avatar
3.5 Stars: 34 Votes
I'm always curious as to (who and) what the tech support people had to say at your autodesk reseller? Did they have any clues? This site is a great forum but let's face it you paid the reseller for the software. They should have some answers.
Fri, Dec 17, 2010 at 11:03:05 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#25
paulh
I've noticed at certain zoom levels some lines will disappear from view or some lines will appear that shouldn't show. I think this is just a processor power thing. The computer can't regenerate the graphice to the screen fast enough so it gets "sloppy" to keep up.
However when I print the view it always comes up correct. Maybe try to print the view instead of doing a screen capture and see what you get.
Wed, Jan 26, 2011 at 3:08:50 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#26
teamleader1
On my computer the doors disappear.  I had someone else open the file on a differnt computer and the doors and other elements are there.
Fri, Feb 25, 2011 at 11:55:22 AM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#27
bulina
4 Stars: 1 Votes
Hello,
I had the same problem on two computers and here is how I solved it: go to Options > Graphics and uncheck Use Hardware Acceleration. Restart Revit.
Hope it works for you as well.
Fri, Feb 25, 2011 at 2:44:04 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#28
suedehart
suedehart Avatar
That solved the problem!  Thanks so much, bulina!  I had given up on this one.
Thu, Apr 5, 2012 at 1:37:10 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#29
BSimmons
Make sure you don't have the Thin Lines icon clicked.  I accidentally had it on and was having the same problem, when I unchecked the box, door swings and slab edges, etc. turned back on.
Ben
Sun, Jan 13, 2013 at 5:26:10 PM | DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011
#30
monstarr
monstarr Avatar
bulina
"Hello,
Hope it works for you as well."
Thank you , this  fix my problem  in revit 2013.
color scheme disappear
Sat, Sep 25, 2010 at 12:49:22 AM
Revit 2014 - Color Schemes disappear when zooming
Tue, Oct 29, 2013 at 10:00:31 PM
zone color scheme "help"
Wed, Sep 22, 2010 at 5:39:33 PM
ZONE COLOR SCHEME
Thu, Sep 30, 2010 at 11:18:26 AM
new color scheme entry error
Thu, Sep 18, 2014 at 6:42:54 PM
12
Page generation time: 2.1616
