191 Users Online (189 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit ROI >> Toposurface Surface Patterns
Fri, Apr 16, 2010 at 8:55:51 AM | Toposurface Surface Patterns
dkobran
I poked around the internet and I cannot find any documentation on creating surface patterns for toposurfaces. How is this possible. This is ridiculous. I am supposed to differentiate the grass, earth, pavement etc. simply with lines? As of now I am using filled regions which are a total pain as they sit on top of everything. Any ideas? Thanks in advance. I just dont understand how Adesk could leave this out -it is the simplest and most obvious thing. It's like they go out of their way to make common sensical things not work. Poor Landscape Architects btw
Fri, Apr 16, 2010 at 9:26:04 AM | Toposurface Surface Patterns
4 Stars: 201 Votes
Why don't you use the "Sub-Regions"??? Check in your HELP menu....
Fri, Apr 16, 2010 at 9:48:30 AM | Toposurface Surface Patterns
dkobran
A sub region, like the base toposurface, does not support SURFACE PATTERNS. What I am saying is you cannot differentiate between surface types without using color (ex. in hidden line).  I need the grass dotted, the gravel pattern, the, the water pattern etc. Just like AutoCAD hatching. Sorry to bring AutoCAD into this but this is drafting 101.
Fri, Apr 16, 2010 at 10:17:48 AM | Toposurface Surface Patterns
TomDorner
4.5 Stars: 25 Votes
You create different materials for things like Site-Gravel and assign both a surface pattern and cut pattern to the material.  Each sub-region is assigned a material then.  Please read the HELP menu for materials and sub-regions.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Fri, Apr 16, 2010 at 10:31:47 AM | Toposurface Surface Patterns
dkobran
I have Revit 2010 installed, with service updates. When I go into a sub region or toposurface and change the surface pattern I get the following message "Topographical surfaces do not support surface patterns. The surface pattern associated with this material will not be displayed on the indicated surface" I am not an idiot -if youre not going to help please dont waste your or my time with an unconstructive answer. YOU read the help menu "...Select the surface material from the list. You can create your own toposurface material. Topographical surfaces do not support materials with surface patterns. See Materials."  Now that we've established this, is there a workaround?
Fri, Apr 16, 2010 at 10:42:53 AM | Toposurface Surface Patterns
TomDorner
4.5 Stars: 25 Votes
Sorry...it has been awhile since I've done sites in Revit.  I normally still do them in AutoCAD and link to Revit.
What I have done is create and area plan and then set the pattern to the area.  This gives me the area and pattern for the surface.  I go even further and do a key schedule set to LEED permiable surfaces and calculate out potential runoff factors.
That said the site tools in Revit have been a sore spot for a long long time.  I don't think they got any attention in 2011 .
A third party has come out with an add-on for Revit that is supposed to improve the site tools for Revit.
http://www.eaglepoint.com/solutions/workflow/office/landscape/landcaddforrevit.asp  Cryingcopy to browser)
I have not evaluated these tools yet so do your research carefully.
Tom
Fri, Apr 16, 2010 at 11:07:52 AM | Toposurface Surface Patterns
dkobran
Thanks. That add on looks amazing but stuff like that should def be included in Revit -its very basic. If it wasn't $1000 I would buy it right now.  Yeah the site tool is a joke but this issue is beyond any of its other limitations. I might try to use CAD for the site plan but from my understanding, the hatch patterns are not conserved when you input the geometry into revit -or do you just import the dwg? I just dont understand why we would have to use another ($5000) program to do this.  Its insane. Its Revit Architecture -If you can't draw everything for a simple architectural project in one program thats a pretty useless program. It seems that the only way to work around this is to use filled regions which is absolutely ridiculous as for each drawing the filled region boundary might have to be changed and it would certainly have to be copied for every drawing (and re-edited in every drawing if changed).  Plus, filled regions sit on top of everything except detail lines really so this is a nightmare.
Fri, Apr 16, 2010 at 12:34:05 PM | Toposurface Surface Patterns
3.5 Stars: 388 Votes
When you link in a site CAD drawing, you can show that as it was drawn in CAD for your topgraphy and use the 3d topo lines to create your 3D topography in REVIT.  So - your hatches in CAD will work.
Tue, Apr 20, 2010 at 9:50:08 AM | Toposurface Surface Patterns
Prophecy99
Prophecy99 Avatar
Nothings perfect.  And I understand your concern for having simple things like this all in Revit..but I believe this is why they call it Revit Architecture.    There are ways you can make this "nightmare" a little easier as others have suggested  but I'll leave that up to you.  One idea is pick lines and the tab key.
Edited on: Tue, Apr 20, 2010 at 9:51:17 AM
Imagination reveals truths reality obscures.
Tue, Apr 20, 2010 at 10:16:40 AM | Prophecy99
dkobran
Quoting Prophecy99 from 2010-04-20 09:50:08
"Nothings perfect.  And I understand your concern for having simple things like this all in Revit..but I believe this is why they call it Revit Architecture.    There are ways you can make this "nightmare" a little easier as others have suggested  but I'll leave that up to you.  One idea is pick lines and the tab key.Edited on: Tue, Apr 20, 2010 at 9:51:17 AM"
No matter how you look at it, no matter how you slice it this is a "nightmare".  If you have to change the something in the site, if you used CAD then you have to edit the linked file in CAD and reimport it. If you have to change something in the site and you used a filled region, the filled region would have to get edited in every drawing as they are not bidirectional (the reason revit exists really). If the toposurface simply supported patterns (why they do not is beyond me -its as if they go out of their way to make this complicated -I cannot think of one reason why this limitation exists) none of this would be a problem. This is a nightmare because this will waste hours and hours and hours of time. This is unproductive. This is not billable time. This is why people dont hire architects anymore. I could hand draw this in a 1/4 of the time. As for "I believe this is why they call it Revit Architecture..." I dont understand that. What does that mean? The site is not a part of the project? I visited Falling Water for the first time yesterday. Do you think Mr. Wright didnt think the site was part of his project? Do you think that he didnt add the site into any of his drawings? Im done listening to excuses for these people. Sorry. This may sound bitter but anytime I find out that hours of my life are going to be wasted because someone else is incompetent Cryingespecially when Im paying them thousands and thousands of dollars) it kinda makes me angry.
Tue, Apr 20, 2010 at 10:36:55 AM | Toposurface Surface Patterns
#11
It is Revit Architecture and the site we currently have is really just for modeling.  Revit does not like the tiny increments you need to do site work.  So - Leave the site in CAD for now and import/link in that drawing.
Tue, Apr 20, 2010 at 10:52:35 AM | Toposurface Surface Patterns
#12
4 Stars: 201 Votes
About this issue what i do: I create the site like i want (Road, Parking, rides and so one) in CIVIL 3D, then i import that site to Revit, in this way i have almost 90% of my site (topo) done in Revit, the other 10%, i adjust in project, the sub-regions, materials...
Tue, Apr 20, 2010 at 12:21:16 PM | Toposurface Surface Patterns
#13
dkobran
So now I have to purchase and learn THREE programs to do one's job... haha okay I'm done no more I promise
Tue, Apr 20, 2010 at 12:30:21 PM | Toposurface Surface Patterns
#14
Look - do it all in Revit if you want.  You can turn off the model site and draw the contours - pvmt - fills just like in cad.  Gheez....Tired of it.
Fri, May 7, 2010 at 9:13:27 AM | Toposurface Surface Patterns
#15
tlcook914
tlcook914 Avatar
I see words like "architecture" and "building", etc. Not words like "scraping dirt" or "grading" or "landscaping". If you're trying to use a program for functions other than what it designed for, then you MUST find other resources to get your job done. Geez... adapt and overcome, my man. If people focused more on the solution rather than the problem, more progress would get done.
btw. You don't have to purchase any other software. Autodesk offers free trial downloads. Figure that one out.
If you think it is too difficult... then it will be.
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
toposurface
Tue, Dec 6, 2005 at 3:49:57 PM
materail surface patterns
Fri, Jun 13, 2008 at 8:06:11 AM
Page generation time: 0.4888
