Forums >> Revit Building >> Technical Support >> Using photos on panels of curtain wall?
Whoops, didn't notice page 2. I'm not sure why there is a focal point. One workaround might be to lump together four smaller rectangular light sources. And to knock back their luminosity. I softened the default luminosity of the light source by 50% or so. Originally the focal point was really burning out the color. I tweaked the properties of the decal some, and I found that bump, luminance, and reflectivity negatively impacted the image. I have them all set to the minimum. Perhaps a layer of glass over the decal might add an interesting effect.
14 Posts No Rating |
alright thanks, especially for the decal effects. it takes me so long to do even a low rendering that messing with each effect takes a long time to decide how the change the decal. i will definately give this method a shot.
Remember, you can always just render a small window when you are testing things out.
Ahh , this could be part of your problem too -- for a light source to render properly, such as from a shape and not a point, you need to have the render quality set to at least medium. revit uses simpler physics for draft and low quality renderings, and this might be derailing you. I tend to test renderings from a 3d view with a tightly cropped scope box, and turn off all unneccessary artificial light sources. this allows "medium" to take a reasonable length of time.
hey bro forget all this fuss..simply when u creating a decal on revit architecture 2009 just check out the setttings. you will see "Luminance(cd/m^2)". it wud be set to not illuminated check out the options in that ..they range from crt monitor screens, led panels, halogen lamp lens just select the desired n hopefully c wat u have been wanting..cheers!!
sorry i just read all ur posts right now ..u mentioned the decal settigs givin u black n white images that are too bright i guess thats because your settings aint perfect...i too had to do alot of custom setings to get my job done..m attachin an image just see if it is kinda sumthin u need.. plz note i havent used high quality images
yes that is pretty much exactly the appearance i was going for. mind if i ask what custom settings you used or at least what stuff you changed? thanks
just a bit more playin with the decal can work wonders for you .....just increased the intensity of the images in decal to get this new render ..plz compare the previous attachment wid it u wud be able to make out the difference pretty clearly..... i believe you have to have different settings for different decal images....sounds a bit hectic but thats the way it goes
"Luminance(cd/m^2)" custom setting was set to 5 " intensity "was set to 75... but as i have mentioned earlier it all depends on the image u choose
Curtain wall panels following profile |
Wed, Oct 12, 2011 at 8:41:57 AM
Can Adaptive Panels Be Used in A Curtain Wall |
Mon, Jun 9, 2014 at 1:49:36 PM
Turning certain curtain panels into spandrel panels |
Tue, Dec 3, 2013 at 1:59:47 PM
Curtain Panels |
Thu, Apr 20, 2017 at 3:44:25 AM
Curtain wall panels changing materials when pinned |
Fri, Feb 26, 2010 at 8:46:05 AM
