162 Users Online (161 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> eyebrow dormer
Mon, Nov 2, 2009 at 9:14:29 PM | eyebrow dormer
hhwse
I am trying to create an eyebrow dormer.  See the attached pdf.  I can create the correct profile by extruding the roof but I can not figure out how to get this shape to slope up along the extrusion.
Tue, Nov 3, 2009 at 2:54:41 AM | eyebrow dormer
tim123
4 Stars: 19 Votes
You can create the roof by making an In-place family in the roof category and then using the blend extrusion.  The family will have to include a void to trim it back to the roof.
Tue, Nov 3, 2009 at 6:48:58 AM | eyebrow dormer
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
I agree with tim i think the only way to accomplish this is with a blend.
J. Allen Ball
Tue, Nov 3, 2009 at 8:11:06 AM | eyebrow dormer
hhwse
I have never used a blend but I am not sure that it is necessary.  This shape is very similar to a barrel vault except that it slopes upward along its centerline.  I have attached a roof that I made by extrusion, which has the correct shape.  This would be perfect if I could rotate it about the front edge so that the ridge was sloping up at 4:12.  See attached.
Tue, Nov 3, 2009 at 8:21:09 AM | eyebrow dormer
4 Stars: 201 Votes
Do that like Tim123 said.....
Tue, Nov 3, 2009 at 8:39:05 AM | eyebrow dormer
hhwse
I do not know how to create an in place roof family.  Can you point me in the right direction?
Tue, Nov 3, 2009 at 8:57:27 AM | eyebrow dormer
hhwse
I tried creating a mass (for the first time in R2010) but can not figure out how to extrude the form along the slope.  Once created Revit will not allow it to be rotated.  HELP!
Edited on: Tue, Nov 3, 2009 at 8:58:18 AM
Tue, Nov 3, 2009 at 12:28:28 PM | eyebrow dormer
tim123
4 Stars: 19 Votes
Don't do a mass.  Do an in-place family using the roof category.  If you're using 2010, click on the down arrow by component on the home panel.  Choose the roof category.  Choose solid, and blend.  The blend works by creating a profile on one Cryingfar) end and another at the other end (close). You could also use extrusion and rotate it if this works.  Create a void extrusion to cut it to sit on the roof.
Wed, Nov 4, 2009 at 2:10:31 AM | eyebrow dormer
hhwse
I created an in place roof component but could not rotate it from level.  The profile is not a blend.  It has a constant section that just diminishes as it penetrates into the main roof deck.  Any other suggestions on how to create this roof?
Wed, Nov 4, 2009 at 3:41:37 AM | eyebrow dormer
4 Stars: 201 Votes
By the image you post you can create that roof with a "Solid Blend" then another "Void Blend" to remove the interior if you want that..... IF the roof is the second image you post (the PDF) then you just need to create a "Solid BLEND"... you don't need to rotate anything, use the BLEND....
Edited on: Wed, Nov 4, 2009 at 3:46:20 AM
Wed, Nov 4, 2009 at 10:20:30 AM | eyebrow dormer
hhwse
I guess I am getting hung up on the “blend” part.  If I understand correctly, when you blend, you transition from one profile to another.  That is not what is happening on an eyebrow dormer.  The dormer profile only curves in one axis.  The lines running back to the main roof are all straight.  Otherwise you cannot get the plywood sheathing to lie onto the rafters.  An eyebrow window is a semi-circular barrel vault that slopes upward toward the main roof.  The profile at the main roof is the intersect point of the dormer and roof.  There is no good way to create the intercept profile without projecting the dormer through the roof.  The main roof has an 8:12 slope and the dormer has a 4:12.   I guess that I could temporarily change the main roof to 4:12 project the dormer and trace the intercept with model lines and then rotate that back up to 8:12 and use the model lines for my intercept profile.   There has got to be a better way!!
Edited on: Wed, Nov 4, 2009 at 10:21:28 AM
Wed, Nov 4, 2009 at 11:30:03 AM | eyebrow dormer
sswensen
sswensen Avatar
If you want you could make a Roof By Face.  See my blog for a video tutorial.
 revitguy.blogspot.com
Wed, Nov 4, 2009 at 12:10:44 PM | eyebrow dormer
#13
tim123
4 Stars: 19 Votes
You can rotate the sweep if you unlock it, but looking at the illustration that you posted, the front bit is vertical.  When you rotate the sweep it will rotate the front face also.  A blend can have the same profile at each end, with the front one lower than the other
Wed, Nov 4, 2009 at 12:15:01 PM | eyebrow dormer
#14
tim123
4 Stars: 19 Votes
Same one done with a rotated extrusion - the front is not plumb.
Wed, Nov 4, 2009 at 4:49:48 PM | eyebrow dormer
#15
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
This is the one you wish the "solid extrusion" has an option to follow along the path just like in AutoCAD. In this case using only ONE profile (the front end) and then extrude it along the path and maybe on roof plane face as well.
 "If you tell the truth, you don't have to remember anything"
Roof dormer/eyebrow vents
Tue, May 9, 2006 at 5:54:56 PM
EYEBROW DORMER OPENING
Tue, Jan 20, 2009 at 4:58:43 PM
Free videos or Sloping Eyebrow Dormer
Mon, Nov 9, 2009 at 7:32:59 PM
Single hung Eyebrow's?
Mon, Dec 3, 2007 at 4:22:54 PM
Room bounding in a dormer.
Fri, Nov 8, 2013 at 2:57:00 PM
Page generation time: 0.2738
