910 Users Online (26 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Revit 2010 Stability
Search this ThreadSearch this Thread | Page 5 of 5 | << Previous 1 | 2 | 3 | 4 | 5
Thu, May 27, 2010 at 4:44:27 AM | Revit 2010 Stability
#61
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Winking i try. i do often opologize for being a jerk, but you really really need to have hardware thats on par with the needs of the software. hardware is money but TIME is money and from a people who are successful in BIM usually have the hardware.
Thu, May 27, 2010 at 5:09:18 AM | Revit 2010 Stability
#62
EspenMA
Its been crashing with different drivers, lastly on 197.59 for Quadro. The graphics card is a FX 1500, so it should be good for Revit 2010. The first time we experienced this problem was on a GeForce 6800 XT with 128 MB RAM (thats why I tested the amount of RAM in use with GPU-Z).
Revit 2010 doesn't need a CAD card to run fluently with 3D-acceleration (Radeon 3450 is just as fast as FX 3400. Go figure). When we upgrade, it will be with Radeons or GeForces with 512 - 1024 MB of RAM.
Thanks for the replies. I didn't notice until later that it was an old thread.
Thu, May 27, 2010 at 7:35:19 AM | Revit 2010 Stability
#63
BubbaZanetti
Here's an update of our progress:
 Revit likes big duo cores. It prefers a 3.4 Ghz Duo Processor to a 1.6 Quad-core for example.
Revit likes a 64-bit OS, 8GB RAM minimum and the pagefile needs to be insane-sized like 20,000 mb.
Set this up and you should be fine. As for particular graphics cards, it REALLY varies a lot. But as long as you have these bare minimums in place Revit should be able to throw around some pretty big models.
Fri, Jun 18, 2010 at 7:19:41 PM | Revit 2010 Stability
#64
Mitsunobu
Mitsunobu Avatar
3 Stars: 2 Votes
<a jerk>
yes I was.
     I was doing the work of an entire team by myself from a small firm that wouldn't listen to any software or hardware requirements I gave them, and following the upgrade standards set by a firm the size that could handle this style of infrastructure...
 I was way too stressed and took it out on the RevitCity boards. I apologize for being such a jerk.
<sorry>
Web Update for Revit
Sat, Oct 3, 2009 at 5:30:17 AM
Something wrong with visibility
Fri, Oct 17, 2008 at 8:18:16 AM
Revit TotD – 2.22.10 | Save the trees, use DWF Markups!
Mon, Feb 22, 2010 at 9:39:08 AM
Revit Crashes at Startup
Wed, Apr 28, 2010 at 7:26:51 AM
Revit TotD - Linked Model Visibility, part 1
Mon, Feb 15, 2010 at 9:08:56 AM
Page generation time: 0.8605
