338 Users Online (10 Members): Show Users Online - Most ever was 658 - Thu, Aug 6, 2026 at 4:08:19 PM
Forums >> General Discussion >> Revit Project Management >> 2010 to 2009 compatibility
Sun, May 3, 2009 at 11:28:04 AM | 2010 to 2009 compatibility
#16
As an Admin, I have different menus then you have so I can not tell if you haave the ability to edit your gallery images.  I know that you can edit your own posts.  If you can not edit your image but wish to remove it, you can send an email to revitcity that has your username and a link to the object.
Your subscription is for support.  As far as I know, you own the software, you don't lease it.
Sun, May 3, 2009 at 11:34:15 AM | 2010 to 2009 compatibility
#17
4 Stars: 205 Votes
You can edit and remove your images...
Mon, May 4, 2009 at 2:44:03 AM | 2010 to 2009 compatibility
#18
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
Thanks,
it worked
Mon, May 4, 2009 at 5:44:04 PM | 2010 to 2009 compatibility
#19
dublamby
I hope this will make everyone happy, as subscription members you are allowed to use 3 versions of Revit and have them on the same computer. At my current employer we bought Revit at Release 2009, We started working on a project that the Architect is using Revit 2008 and has told us they will not be upgrading. We inquired about how to get Revit 2008 and were told by our reseller that we are allowed to have the current version and the 2 previos versions of Revit on our computers and can any version we want to. This being said if your consultants don't want to upgrade the project, and I can understand why (that is another conversion about the upgradability of large projects), then don't uninstall the previous version of Revit when the new version comes out. If you need to install the previous versions, and you don't have the DVDs, you can download them from the subscription center.
Mon, Oct 5, 2009 at 6:59:37 AM | 2010 to 2009 compatibility
#20
gridcitypunx
and i love that i was so excited about having a new program that i opened up my latest project saved it a couple of times found out i couldn't modify mass profiles like in 2009 and low and behold i'm stuck with 2010. Changing a mass profile means deleting it and starting again. Wow! Thanks revit!
Mon, Oct 12, 2009 at 8:34:18 PM | 2010 to 2009 compatibility
#21
RevitStudent123
Yes but one has to export the Revit 10 as a IFC. Explore the IFC options dialog box. In this box there are
dozens of materials or creteria you change from "do not export" to "export". My gut hunch is that 2010 rendering
set ups do not go over completely to 09. ALso one can export a revit 10 as a acis file and open it up in Revit 09.
I have revit 08 and I am upgrading to 2010, its supposed to be the next level in higher level BIM.
Here is some of my recent 08 work. I am in San Diego and always looking for full time work or anything
else. If your in San Diego look me up. We could have a cold one or hang out at the beach and watch the
local scenery. Good luck 858-373-8914 vince1234@inbox.com
Revit TotD – 7.31.09: Legend Tagging
Fri, Jul 31, 2009 at 8:08:39 AM
WIndows 10 Update 1909 Revit does not work
Thu, Sep 19, 2024 at 7:46:59 AM
Revit TotD – 2.22.10 | Save the trees, use DWF Markups!
Mon, Feb 22, 2010 at 9:39:08 AM
Revit TotD - Linked Model Visibility, part 1
Mon, Feb 15, 2010 at 9:08:56 AM
Revit Crashes at Startup
Tue, Apr 27, 2010 at 6:53:45 AM
Page generation time: 0.1545
