51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Change in grade
1 Posts No Rating |
Is there a way to create a ground plane which has different elevations? The house I created is built into a hill so the entrance is at 4'-6, but the back of the house should be at ground level. Is there a way to create a ground plane which will show this?
using a ramp or a toposurface should work.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Are you trying to create a site toposurface with varying grade levels or a floor that changes levels or has slopes? . For the outside of the building use a toposurface with varying grade points. For the inside use floors (sloping), stairs and ramps. . It depends on how you want the interior to match up with the exterior.
Grade Hatch in Elevation |
Wed, Aug 6, 2008 at 12:03:16 AM
Wall finishes and grade |
Tue, Aug 31, 2010 at 12:33:10 AM
Sidewalks that curve no change in grade |
Sat, Mar 22, 2008 at 12:15:19 AM
SPLIT SURFACE and GRADE REGION |
Thu, Sep 15, 2005 at 7:54:24 PM
invisibility below grade |
Fri, Jun 29, 2007 at 9:38:06 AM
12
Members: | 1977411 | Objects: | 22860 | Forum Posts: | 152167 | Job Listings: | 3 |
