Forums >> Revit Building >> Technical Support >> Shading w edges in plan
Hi, i am trying to see if its possible to have a good looking colored planview for my salesplans directly from revit but i cant seem to figure out why in some planviews my floors show its shading color and in others it doesnt. anyone encounterd this and knows why this is? using rac 2008 Kind regards, D
Edited on: Mon, Oct 13, 2008 at 3:11:19 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
It would appear that it is only the floor that is not displaying properly. Check that this is the same type of floor and that the element properties are the same. Have you considered rendering the plan for your presentation? This can be achieved by creating a section box of a 3D view and then orientating it to the plan. The result can look very good.
the orient 3d view to plan thing isnt going to work out, there is to much info that doesnt show, the floor used in both images is the same floortype just in a different view. i did my best to set every viewport option to the same but it has not worked.
peace is the path."
Mahatma Gandhi.
i would create a view template from the view that is correct and apply to the other view. HTH
Edited on: Mon, Oct 13, 2008 at 10:11:40 AM
did not work
peace is the path."
Mahatma Gandhi.
A few things you can check. 1. Do you have one on Hidden line and one on Wireframe? 2. Check "Color Scheme Location" and see if one is set to Foreground and one to Background. 3. Check to make sure Color Scheme is assigned. 4. If you are using just "Shaded View" then check VV to see if there is a Floor Overide. 5. Change to a Color Scheme if you are using "Shaded View"
----------------------------------- BallewDesigns.com |
tytytytytytyty it was the colos scheme thing that was set different, the good one was set to none and the bad one was set to a preset, i set that one also to none and now it looks fine, tnx!!! D
peace is the path."
Mahatma Gandhi.
shading with edges problem |
Wed, Nov 17, 2010 at 6:49:49 AM
Shading with edges in Plan View |
Tue, Dec 1, 2009 at 9:15:29 AM
Shading with edges in plan |
Mon, Sep 8, 2008 at 4:18:14 AM
TOO DARK Shading with Edges Revit 2009 |
Mon, Aug 25, 2008 at 6:57:19 PM
11
Problems plotting "shading with edges".................. |
Mon, Mar 24, 2008 at 8:01:09 AM
Members: | 1990789 | Objects: | 22877 | Forum Posts: | 152180 | Job Listings: | 3 |
