54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cut pattern under graded region or slabs not showing in plan
Tue, Jul 22, 2008 at 11:18:35 AM | Cut pattern under graded region or slabs not showing in plan
everist
3 Stars: 2 Votes
I am using Revit 2009. In plan, the cut pattern of my topography is not displaying under graded regions or slabs. I have modified the "elevation of poche base" in the Site Settings, but this only impacts the display of the site in section. Any assistance is appreciated.
Tue, Jul 22, 2008 at 11:57:14 AM | Cut pattern under graded region or slabs not showing in plan
4 Stars: 201 Votes
Hi, "In plan, the cut pattern of my topography is not displaying", right the "Cut Pattern" it's just to Sections, can you put some screenshots to figure what are you talking about?
Tue, Jul 22, 2008 at 12:05:35 PM | Cut pattern under graded region or slabs not showing in plan
everist
3 Stars: 2 Votes
See the attached image. When My plan is cut at or below where a slab intersects with teh topo surface, the plan view does not poche. If I cut through the face created by a pad object the poche will show, but if you cut at or below the line that I have highlighted as "intersection", I do not get a poche of the earth in plan.
Thanks for the interest.
Tue, Jul 22, 2008 at 12:08:04 PM | Cut pattern under graded region or slabs not showing in plan
everist
3 Stars: 2 Votes
The result makes sense becasue a topo is a surface object, but the earth poche should be able to display in plan beyond the base of the pad.
Tue, Jul 22, 2008 at 12:16:53 PM | Cut pattern under graded region or slabs not showing in plan
4 Stars: 201 Votes
can you put the right image with shade? do you see the pattern in SITE plan?
Tue, Jul 22, 2008 at 12:24:56 PM | Cut pattern under graded region or slabs not showing in plan
everist
3 Stars: 2 Votes
I don't see the pattern in the SITE plan. See attached. Everything shown as white in the plan to the left beyond the buildings at the right should have an earth poche.
Tue, Jul 22, 2008 at 12:32:12 PM | Cut pattern under graded region or slabs not showing in plan
4 Stars: 201 Votes
You must pick in the PAD and edit the properties and change the material and the cut and surface pattern equal like the topo site...
Tue, Jul 22, 2008 at 3:33:37 PM | Cut pattern under graded region or slabs not showing in plan
everist
3 Stars: 2 Votes
Tue, Jul 22, 2008 at 3:42:19 PM | Cut pattern under graded region or slabs not showing in plan
4 Stars: 201 Votes
Can you see?
Tue, Jul 22, 2008 at 4:13:41 PM | Cut pattern under graded region or slabs not showing in plan
everist
3 Stars: 2 Votes
On this attachment, look at Level 1. At Level 1, below "pad A" and "pad B", I should get an earth hatch, just like on Level 2 below "pad B". In plan, if you do not cut through the center of the pad vertically, like Level 2 is here, you don't get a hatch.
Tue, Jul 22, 2008 at 4:33:10 PM | Cut pattern under graded region or slabs not showing in plan
4 Stars: 201 Votes
I think the problem isn't in the "Hatch" in the plan but it's because the "View Range" in LEVEL 1, because in LEVEL 2 we can see the hatch (level 2 is more height than level1) so try to see VP>View Range....
or can you put the model here to download to see what a hell is going on?
Tue, Jul 22, 2008 at 4:42:16 PM | Cut pattern under graded region or slabs not showing in plan
everist
3 Stars: 2 Votes
I have attached two files, one is a diagram.  The area in b lue should be hatched. I have also attached the site Revit file.
Tue, Jul 22, 2008 at 4:45:09 PM | Cut pattern under graded region or slabs not showing in plan
#13
everist
3 Stars: 2 Votes
I can't upload the revit file. I'll have to set up a test file. I'll do that later. Thanks for your help.
Tue, Jul 22, 2008 at 4:48:00 PM | Cut pattern under graded region or slabs not showing in plan
#14
4 Stars: 201 Votes
Because you only have 2 Mb to upload the file....
Tue, Jul 22, 2008 at 4:48:50 PM | Cut pattern under graded region or slabs not showing in plan
#15
4 Stars: 201 Votes
My email is "thyphoon38@gmail.com"
Topography - Cut and Fill for Graded Region
Fri, Feb 4, 2011 at 11:31:15 AM
GRADED REGION
Tue, Apr 30, 2013 at 8:10:21 AM
Plan Region problem - walls/slabs/framing displaying outside the region boundary
Tue, Jun 23, 2009 at 4:46:32 PM
Plan region not showing lines in detail view [ 1 2 ]
Mon, May 11, 2015 at 11:17:48 AM
15
Site plan visibility problem with graded region
Sat, Jan 8, 2011 at 12:57:02 PM
Page generation time: 0.8971
