153 Users Online (152 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> New vs. Existing Contours
Mon, Apr 14, 2008 at 1:37:57 PM | New vs. Existing Contours
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
We have been messing with the graded region feature on our Topography.  We have successfully created two topos (one in existing phase and one in new construction phase).  However there is no differenct when you're in hidden line, and you have show all set in your view properties.  You can see both New and Exist. contours, but they are all the same line weights etc.  Is there a way to show the NEW contours as a solid line?  Thanks,
Lorne
Denver, CO
Revit Architecture
Wed, May 14, 2008 at 12:49:31 PM | New vs. Existing Contours
callie
I just replied to your original message as well.  Did you figure this out?  We like to show the existing contours as dashed and then in a heavy line show the new contours and where they are connecting to the old if that's the case.
Wed, May 14, 2008 at 1:31:35 PM | New vs. Existing Contours
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
No I didn't figure this out.  I only figured out how to make the primary contours heavy and the secondary contours lighter.  So unfortunately, I have not found a way to do this.
Does anyone know how to do this?  Is it even a possibility in Revit 2008??
Denver, CO
Revit Architecture
Wed, May 14, 2008 at 1:44:56 PM | New vs. Existing Contours
callie
Thanks for responding.  How did you get both to show up at the same time with lighter existing and heavier new contours?  At least it's a start.
Wed, May 14, 2008 at 5:11:15 PM | callie
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Quoting callie from 2008-05-14 13:44:56
"Thanks for responding.  How did you get both to show up at the same time with lighter existing and heavier new contours?  At least it's a start."
Hello Callie,
Correction on your question.  I did not actually get "existing" lighter or "new" heavier.  I got the primary contours, and secondary contours heavier and lighter.  Meaning, every 10' or 5' or user specified are considered primary contours and the rest are secondary.
To do this: first set how often you have your primary lines.  Go to settings>site settings   In there you can change and specify the primary and secondary contour increments.  I have mine to 5'-0" and secondary to 1'-0".
 Next you need to change your object styles.  Go to Topography and select the plus sign next to it.  You'll see primary and secondary contours there.  You can override the lineweight there.
Make sense?  HTH,
Lorne
Denver, CO
Revit Architecture
Wed, May 14, 2008 at 10:22:23 PM | New vs. Existing Contours
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There are two ways to do this,
By view (probably the best solution).  That is, simply select the element, right click and choose override graphics in view, then adjust lineweight and style as needed.
Other solution involve upgrading to 2009 as in the graphic overrides of the phase filters you now have more control.  That is you can control lineweight, colour, type for both cut and projection items of that particular phase.
Regards,
Chris.
Thu, May 15, 2008 at 10:04:31 AM | New vs. Existing Contours
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
The Problem with overriding graphics in view.  Is when you use the grade region tool, Revit copies the existing grade and creates a new topo in the "New Construction" phase and if I override graphics in view of the new topo, all the contour lines become solid.  The contours are the same as existing where we didn't grade the new topo.
Does that make sense?  What I did in the mean time, was create a small topo without the grade region tool and just overrode those graphics to be solid.  But if you use the tools Revit provides to creat new vs existing topos it doesn't work the way it should be.
 Thanks for the help,
orne
Denver, CO
Revit Architecture
Wed, Jun 11, 2008 at 10:13:51 AM | New vs. Existing Contours
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Does anyone know how to show the CHANGED contours as dashed??  when we use the graded region tool, it copies the existing topo and has the exact same contours, co then they are solid on top of existing.  I just want to show the changes in contours that changed around the house, not the entire topography.
Denver, CO
Revit Architecture
Wed, Jun 11, 2008 at 11:35:45 AM | New vs. Existing Contours
3.5 Stars: 389 Votes
Lorne17,
If you did the graaded region as a phase, you should be able to override the linetype.
Select settings / phases - select the phase you have graded in and pick the graphic over-rides for the line type.
Thu, Jun 12, 2008 at 11:23:19 AM | New vs. Existing Contours
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
That is how we have been using the graded region tool.  We use the phase filter and add the new contours as solid, and existing as dashed.  But the problem is, say I have a topography of 5 acres.  Now I make that topo existing phase (dashed).  Then select the graded region tool & automatically it copies the 5 acres in place and allows me to change points and elevations and whatnot.  Let's say I change the points only in 1 acre of the topography.  Now when I finish the new changed topography the rest of the 4 acre contours are the same and there for are laying on top of the existing topo making all the lines solid (because the new phase is solid lines).  Does that make sense?  All we want to see is how the contours in that 1 acre I changed show up as solid. The rest we want dashed, because they're existing.
Take a look at the image.  I did the steps above, then made the new topography as transparent in order to show the dashed lines below.  But you can only see where I changed the lines, not the rest of them because the new contours are laying on top of the existing.
Am I making any sense?  Or just digging a deep hole?
Denver, CO
Revit Architecture
Thu, Jun 19, 2008 at 11:22:29 AM | New vs. Existing Contours
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Anyone please?  Really trying to solve this graphical problem we have.
Does anyone know if this is easier done in Revit 2009??
Denver, CO
Revit Architecture
Thu, Jun 19, 2008 at 12:38:38 PM | New vs. Existing Contours
Although I think REVIT is showing it right - finished grades are all solid (even if there is no change). Try splitting out the area you are grading first. REVIT seems to thik the split area as a seperate topo. Then grade that area.
Edited on: Thu, Jun 19, 2008 at 12:39:10 PM
Thu, Jun 28, 2012 at 8:35:21 AM | New vs. Existing Contours
#13
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
@lorne17-  Did you ever figure out how to make the existing and new linetypes different?  I am having basically the exact same problem
Thu, Jun 28, 2012 at 8:45:44 AM | New vs. Existing Contours
#14
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Unfortunately I have not worked on this issue since 2008.  I really haven't used the grading tool since then.
Can anyone else help chime in?  You can try what WWHub said above.
Sorry I can't help further,
Lorne
Denver, CO
Revit Architecture
Thu, Jun 28, 2012 at 9:23:27 AM | New vs. Existing Contours
#15
If you use the phases, existing will automatically show as dashed and new as solid.
Changing existing and new contour lines
Tue, Jul 17, 2012 at 9:08:56 AM
Create new and existing topo lines
Wed, Feb 24, 2010 at 12:11:13 PM
Smoothing contours...
Tue, Feb 17, 2009 at 8:43:14 AM
printing contours
Fri, Jul 30, 2010 at 2:19:00 PM
contours
Mon, Apr 24, 2006 at 5:16:04 AM
Page generation time: 1.6911
