Forums >> Revit Building >> Technical Support >> Radiate material problems
11 Posts No Rating |
Hi everyone.. I have som problems with Radiate.. When i radiate my drawing, one a few materials apear.. Some trees and some water, but all the other material doesn't show!! What is wrong? what can i do?! Rasmus
Radiate it's proprely to interior renders, when you talk about "Trees..." i supose you are trying to render a exterior scene, but, when you radiate you must click several times in "continue" until your "Residual" is low "e.g. 0.15 or 0.10", then after you radiate your scene you can Render and everything it's ok....
Yes, rendering is completely seperat from radiating. Once you radiate, render and your materials will show up in full.
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
Okay.. thanks a lot, but i still dont really get what radiate is then? can you explain it simple? And the material didnt show, because i moved the project, and not my custom materials ;-) And thanks for your help!
i have a problem with Radiate.. When i Radiate, the light looks wierd.. the light on the floor looks good, but on the walls and ciling it doesnt! You can se the picture.. Anyone know what to do? Rasmus
OK RASMUS, this problem appears several times when you don't follow some rules: 1º - you must join your walls each other and join with the floor and the celling, use "JOIN GEOMETRY and EDIT WALL JOINS". 2º - After this, you must radiate several times until your "Residual" goes to "0.10 or 0.15", it takes several hours (depend of your hardware) in Revit, if you use 3DS MAX or VIZ it's faster but in this case (Revit) you have to be patient... Follow this simple rules and in the final you have a realistic Render... Enjoy.
i will get right on it! Thanks a lot! Rasmus
i still have some problems with this... i joined the walls and floor and ceiling, but there are still some problems with the shadows from the Sofa, its very pixilated? i dont know how to improve the shadow quality
Attatch the image, what's the final residual radiate?
i look like the picture already atached, the residual was 0.07
it*
I don't no man, are you working with SP3 installed? with 0.07 residual must be fine, are you render with 300 Dpi?
wierd.. sp3? i dont hink so.. i work with Revit 2008 Architectual.. well.. thx for trying, i will work with it for some time.. And MAKE it work..
Rasmus, Autodesk launch 3 Service pack for Autodesk products including Revit, so, you must install Revit SP3 and i think your problems are solved...
Raytrace / Radiate |
Wed, Aug 1, 2007 at 8:07:00 PM
Rendering with 'Radiate' |
Mon, Aug 4, 2008 at 6:29:20 PM
Radiate & Glass in Revit Architecture |
Thu, Sep 13, 2007 at 2:36:34 PM
Material problems Please Help! |
Sat, Apr 21, 2012 at 10:58:38 AM
Material Takeoff problems |
Thu, Oct 12, 2017 at 10:53:40 PM
Members: | 1771617 | Objects: | 22438 | Forum Posts: | 151914 | Job Listings: | 3 |
