89 Users Online (88 Members):
Forums >> Revit Building >> Technical Support >> Annotating Views
10 Posts No Rating |
Hey everyone, Once again I need your services. I am trying to figure out how to annotate my plans ie: (floor plan notes, site plan notes....etc.), I would like to be able to insert a note in the plan and then have a legend calling out the respective notes. Please if you know how to do this, or you have any suggestions it would be much appreciated. RW
Read your REVIT help under keynote.
thank you! I really appreciate it
I use Note Blocks. You can get one from the Annotation Folder. I have made several with circles, squares, and diamonds so that I can have several different Note Blocks (ie. System Notes, Keynotes, Bath Notes) in a single model. I prefer Note Blocks because you can edit the text inside Revit. It is as easy as editing any other type parameter. You can find more info on Note Blocks in the (F1) Revit help files. Hope this helps.
----------------------------------- ArchWestCY |
Annotating displaced elements |
Fri, Nov 22, 2013 at 1:38:20 AM
Annotating linked files |
Tue, Nov 20, 2007 at 11:42:39 AM
Making annotating elements faster? |
Tue, Oct 6, 2015 at 7:41:44 AM
Drafting a model based detail |
Thu, Mar 25, 2010 at 9:35:13 AM
Revit building in ACA 2009 project manager |
Mon, Dec 15, 2008 at 9:08:31 AM
Members: | 1998379 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
