70 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> Can I turn off visibility for elements under the toposurface?
When I do a section, I would like to be able to turn off the visibility of elements that are under the toposurface. Does anybody know how this can be done? Is it a setting I can toggle, or is there some other clever way? Thanks Jesper "Revit newcommer"
You can actually hide any element in a Revit model without going to visibility settings. Click on an object(s), right click, and click on hide in view. You can either choose element or category. In order to see what you have hidden, just click on the yellow light bulb and the screen will turn pink and show you what is hidden in that view.
how visibility of filter work with the turn on/off of certain category? |
Thu, Jan 13, 2011 at 4:03:48 PM
Turn off the same linked elements in every view [ 1 2 ] |
Thu, Nov 29, 2012 at 2:51:08 PM
23
Turn off wall visibility on upper floors... |
Fri, Mar 4, 2011 at 2:24:23 PM
Visibility elements in a room tag |
Mon, Aug 9, 2010 at 2:58:33 PM
linked file visibility |
Fri, Aug 23, 2013 at 8:05:11 AM
Members: | 1998849 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
