90 Users Online (89 Members):
Forums >> Revit Building >> Technical Support >> newbie - need help with dimension
11 Posts No Rating |
hi, ive only been using revit for about 3 months now, i need some help on how to put in dimension, ive tried to follow the programmes instruction but it dont work, so i click on the blue ruler under the wall but it doesnt give me the dimension i want, also is there way where i can put dimension on everything at once? can anyone help please, thank you kunal
A few dimensioning tips. You can dimension using the dimension tool and tab around elements to get what you would like. There is also a toggle in the settings menu/temporary dimensions to change the temporary dimensions (the blue ruler you speak of) to be strung from wall center or wall face and for window dimesions to be from centerline or opening. You can dimension seval openings at once (click on wall) or sevaral grid lines. If you need to remove one of those dimensions, say in the middle of the string. It becomes rather difficult to do so.
Dimensioning in Revit is always continuous, until you click on the dimension line itself. If you continue clicking on objects that you want to dimension then the dim string will continue.
thank you for your help, got the hang of it now
NewBie - Wall dimension tips |
Sun, Apr 9, 2006 at 3:27:32 PM
demension text color |
Tue, Jan 31, 2023 at 1:47:01 PM
Activate Dimension |
Tue, Dec 13, 2011 at 12:53:44 PM
Newbie |
Thu, Apr 27, 2017 at 9:35:53 AM
Dimension strings not adding up to the total length dimension string (2017) |
Fri, Mar 23, 2018 at 1:33:58 AM
Members: | 2000792 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
