91 Users Online (89 Members):
Forums >> Revit Building >> Technical Support >> Can I arrange parameter list?
20 Posts No Rating |
Hello, Creating a window family and adding instant parameters using Revit 2008. After adding like six dimensioned instant parameters, I have found that they are in no particular order when I see them listed in the element settings. Is there a way I can arrange them (like by moving them up and down or something) so they could be better organized in order? How does Revit determine the order they go in as well? I have attached the window family for you to look at and the unorganized parameter list I am referring to is under Dimensions category. Thanks in advance.
1 Posts No Rating |
I am having the same issues. I also can not delete family system parameters that are unused.
NO.. They will arrange alphabetically. You could rename or add a letter at the beginning to force them to organize the way you want. Remember don't use -=+/* in the names.
----------------------------------- BallewDesigns.com |
You will not be able to delete the ones that are built-in to the family template. You can delete the ones you create.
re-arrange design options |
Tue, Jan 29, 2013 at 11:16:34 AM
View List doesn't have parameter to show them in order of number on sheet? |
Fri, Aug 26, 2016 at 2:48:10 PM
Any way to change the order of Revit Design Options in the list? |
Tue, Nov 1, 2016 at 12:33:21 PM
Adding a check box list to a drawing list |
Thu, Apr 21, 2016 at 5:17:56 PM
Filtering placeholder sheets by discipline in a sheet list |
Thu, Jun 23, 2011 at 12:27:04 PM
Members: | 1986906 | Objects: | 22874 | Forum Posts: | 152182 | Job Listings: | 3 |
