103 Users Online (100 Members):
Forums >> Revit Building >> Technical Support >> Wall reveals - dimensioning to their center & easily overriding lineweight
20 Posts No Rating |
Hi everyone - I'm on Revit Building 2008, and I am trying to build a wall reveal profile that will allow me to dimension to the center of the reveal. I've tried making the center front/back axis a strong reference, and that hasn't worked. I added a small traingular piece to the center of the shape, and that worked, but it creates extra lines in the elevations, which is not ok. Any advice would be appreciated. Also, does anyone know how to easily override their lineweight in elevations? Changing the wall projection lineweight also canges the wall's outside edges, which should be darker. Is the linework tool my only option? I've been doing it this way for years and am hoping there is a more efficient way.... Thanks! -Jen
Put an invisible line in the profile family and you should be able to dimension to that.
Revit reads that as part of the profile, and gives you the "highligted lines are overlapping yada yada yada" error message. Thanks for the suggestion though - any more?
Your right .... sorry about that. I've used the invisible line trick in other families but forgot about how profiles work.
dimensioning to a center mark of an arc |
Wed, Jul 5, 2023 at 3:13:09 PM
Tilt Panel With Reveals Using Reveal Family Profiles! |
Sat, Feb 26, 2011 at 5:42:16 PM
Revit 2008 - Dimensioning Curtain Wall |
Tue, Feb 19, 2008 at 5:26:46 PM
Lineweight of In-Place Families |
Thu, Apr 28, 2011 at 6:43:20 PM
Wall Reveals |
Mon, Jul 9, 2007 at 11:55:45 AM
Members: | 2002612 | Objects: | 22887 | Forum Posts: | 152181 | Job Listings: | 3 |
