136 Users Online (135 Members):
Forums >> Revit Building >> Technical Support >> Elevations - remove brick coursing
64 Posts No Rating |
in revit 2008 archi, how do you remove the brick coursing/tile pattern from the elevations. tia
Edit the Wall type- either change the material used for the brick leaf, or edit the brick leaf material to remove the model hatch pattern. Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
You can also select the wall, right click, choose :Override graphics in view-> and choose category (effecting all walls) and uncheck the visible option in in the walls row, and patterns column. The difference is that what IDN101 tells you to do turns off the hatch in every view, everywhere, while the above turns it off only in that view. Your desired end result for the construction set is what will determine which method you use. Cheers.
**Using Revit Architecture 2009, 2011, and 2012** |
Just thought of another one! How about painting the faces (of the walls where you don't want to see the hatch) using the Paint Tool (with a unhatched material selected)? Regards, Ian
thanks, will give it ago
Brick Coursing Changing to Vertical At Wall Opening |
Mon, Dec 24, 2012 at 2:17:38 PM
Brick Reveal Issue! Help! |
Wed, Mar 4, 2009 at 10:26:25 AM
Adjust hatching to follow brick courses or tiling for tiling layouts |
Tue, Aug 5, 2008 at 10:14:12 AM
help with shadows on elevations |
Fri, May 16, 2008 at 1:52:59 PM
New to revit - how would i get a drawing like this from ACAD |
Fri, Nov 9, 2007 at 6:09:05 AM
Members: | 2001914 | Objects: | 22887 | Forum Posts: | 152182 | Job Listings: | 3 |
