121 Users Online (119 Members):
Forums >> Revit Building >> Technical Support >> Slab Edges on Sloped Floors
Revit Architecture 2008 Is there a way to apply a floor slab edge sweep to a floor that is sloped using the points function and its structure has variable layers? Could it be the profile or is it that you can't add a floor slab edge sweep to a floor with variable thickness? Any help would be great, Thanks.
14 Posts No Rating |
Did you ever find a solution? I'm running into the same issue.
Not yet, other thn by tricking Revit by using in-place families to replicate the grade beams. I'll post to Revitcity with a solution if i fgure it out.
32 Posts No Rating |
Not sure if you have figured this out yet, but check out this link http://revitcity.com/forums.php?action=viewthread&thread_id=14005 If you remove the slope arrow, add the slab edge, then re-slope the slab, the edge goes with it
slab edges are brown |
Thu, Apr 28, 2011 at 8:58:20 AM
Cutting floor slab edges out of pads |
Mon, Oct 25, 2004 at 10:43:54 PM
Slab Egdes & multicategory schedules. |
Mon, May 16, 2011 at 2:04:35 AM
Slab edges - square instead of plum? |
Thu, Apr 2, 2009 at 7:58:19 AM
Create Void as Slab Edge |
Sun, Oct 2, 2016 at 11:39:37 PM
Members: | 1992136 | Objects: | 22880 | Forum Posts: | 152184 | Job Listings: | 3 |
