91 Users Online (90 Members):
Forums >> Community >> Newbies >> Footings for Slab Foundation
I am trying to create the footings for a slab foundation. I have used the option that will allow you to put the footings by selecting the edge of the slab. I need the footings and foundation wall to be approximately 3 feet down from the slab to the bottom of the footing. The footings in the application will only go down 10 or 12 inches. What do I need to do to put in the proper depth of footing for the slab foundation? Any suggestions?
The haunched area of the slab edge is defined by the profile listed in the type properties(edit the element property). Under the construction parameter is the profile which will allow you to change by clicking in the value box. If the size you want is not listed, you will have to create one and load it. See help for profiles.
Changing Linetypes in Foundation Plan |
Thu, Mar 18, 2010 at 7:18:01 AM
Slab Foundation Help |
Thu, Sep 22, 2011 at 11:39:04 AM
Slab Foundation Questions |
Fri, Mar 7, 2008 at 10:56:28 AM
Foundation Schedule - no footing thickness field - help! |
Fri, Dec 2, 2011 at 10:24:44 AM
12
dashed line for foundation footings? |
Thu, Feb 9, 2006 at 4:04:06 PM
Members: | 1998919 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
