73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Black dots appearing in columns when using pattern override
4 Posts No Rating |
This is my first post here, so hi everyone! I'm using Revit architecture 2008 and having a problem when using custom visibility graphics for structural elements. Basically I am modelling 2 fairly large (18 storey) buildings in separate model files and then linking them together into a separate file for drawings sheets. Seems to work well, but initially I set my columns to have a red fill pattern to assist the structural engineers co-ordination. I wish to keep that pattern for the GA's but have them grey on other drawings for example fire strategy drawings. So I go to visibility graphics/links/pick the relevant building/custom/model/structure/pattern override and pick a grey colour. This works great except for the large black dot which appear at the centre of every column and sheer wall! I can't figure out why they appear otr how to get rid of them. I've tried a search through the forums but can't find anything similar. Aplologies if this is a bit wordy but I thought the more descriptive the better, in order to help you help me. Cheers
4 Posts No Rating |
No one, come across this one before? I've been in contact with our support company who think the dots may be analytical lines, but they don't know how to turn them off in revit architecture. Anyone know how to do this?
hi firstly i'm not sure if it is the anlytical model points but if it is this is how to turn them off view properties visibility graphics override tick the show catagories from all disipline button expand out you structural columns untick rigid links and anlytical model hope this helps.
4 Posts No Rating |
That's sorted it! Easy when you know how I suppose. Makes you wonder why we pay for tech support? All hail KING REVIT!!
Hi Gazbo, I do revit consultance and support for many clients. It sounds like your support isn't up to scratch. If you feel your support is expensive not worth the cost then maybe you may consider giving me a chance. I do both in-house support (depends on where you are based) and web support. You can contact me at kingrevit@gmail.com
Cut Pattern - Timber Columns in plan views to black ? |
Tue, Mar 18, 2014 at 7:41:46 PM
blue dots in linework |
Wed, Aug 18, 2010 at 4:13:09 AM
cut pattern override view template |
Tue, Mar 31, 2015 at 10:47:55 AM
Linework Tool and remaining black dots |
Mon, Jan 19, 2009 at 9:54:45 PM
Rendering Revit Architecture 2009 - Little Black dots!!!! |
Fri, Dec 19, 2008 at 5:42:49 AM
Members: | 1995855 | Objects: | 22885 | Forum Posts: | 152175 | Job Listings: | 3 |
