147 Users Online (146 Members):
Forums >> Revit Building >> Technical Support >> Message Format
everybody's words are strung out.. not only are my words strung out but spaces between words are missing.. and i format my message in notepad perfectly first.. i found if i move words around in the revit city message box is posts even worse.. does anyone know how to properly format a message for posting here? look at the words in this post: http://www.revitcity.com/forums.php?action=viewthread&thread_id=8764
I think your problem is on your end. The post you refer to is fine. Yor post looks fine except it is not as wide as the view window ... must be because you did it in notepad. Check out the site on a different system. Don't know what could be causing your problems but they are on your end.
interesting.. so you are saying that the way you are seeing for example the message you just posted above is NOT two long lines with just the word "end" for the third line?
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016 |
Tue, Oct 4, 2016 at 9:09:33 AM
Format Label Date/ Time Stamp [ 1 2 ] |
Thu, Oct 22, 2020 at 12:22:53 PM
21
Keynoting and the new 2004 CSI Format |
Thu, Sep 24, 2009 at 3:05:29 PM
13
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 9:12:33 AM
Message when opening file |
Wed, Nov 27, 2019 at 1:00:39 PM
Members: | 2002328 | Objects: | 22887 | Forum Posts: | 152181 | Job Listings: | 3 |
