18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Minimum Subwall Height In Stacked Wall
Our client has a very specific tile pattern for their restrooms. In order to achieve this, I have created several walls with different surface patterns & colors. I then use the stacked wall to assemble the various different walls. It works great as I am also able to offset the tile grout lines to the clients specs for each subwall. Now comes the problem - I have 1" tile liner bands. Revit appearts to allow a minimum height of 1.25" for a subwall within a stacked wall. Does anyone know how to override this? I realize that stacked walls are more for walls with variable thickness. Is there a better way that I can create tile patterns? FYI - Here is the pattern: 2 rows 1" x 1" Black6 rows 6" x 6" White1 row 1" x 6" White (25% offset) - problem part1 row 6" x 6" White (50% offset)1 row 1" x 6" White (75% offset) - problem part8 rows 6" x 6" WhiteRemaining gyp wall to top THANKS.
----------------------------------- Revit Architecture 2010 |
sorry - that didn't come out the way i meant it. Heres the pattern: 2 rows 1" x 1" Black 6 rows 6" x 6" White 1 row 1" x 6" White (25% offset) - problem part 1 row 6" x 6" White (50% offset) 1 row 1" x 6" White (75% offset) - problem part 8 rows 6" x 6" White Remaining gyp wall to top
2013 - Stacked wall problems |
Thu, Dec 12, 2013 at 8:23:39 PM
Stacked Wall Problems |
Wed, May 18, 2016 at 9:10:52 AM
How to overlap wall types in a vertical plane in a stacked wall. |
Thu, Oct 3, 2013 at 4:30:18 PM
Mass Floors with a Minimum Height/Clearance |
Wed, Apr 18, 2012 at 5:25:50 AM
Brick Ledge? |
Wed, May 18, 2011 at 10:11:35 AM
