26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Glass Covered Buildings
3 Posts No Rating |
Using Revit 8.0 Hi guys i'm trying to design my grilfriend's dream apartment, and she loves those glass buildings, now i know that in thes ebuildings you can see out through some of the glss panels, but not through others becuase there are walls, how would i make this on revit...more specifially make it so that if it seems as much glass as possible but if there is a wall behind one not have it throw off the shade of the glass the type of building i;m talking about looks like this: http://images.jupiterimages.com/common/detail/28/64/22866428.jpg thanks everyone for their help or even for looking over my question
You will use curtain systems/ sloped glazing(roof tool)
3 Posts No Rating |
Thank you for trying sdbrown but unfortunately that doesn't work. This is because althought galzed he wall behind the glass is still seen compared to the glass without the wall behind it. Thank you for trying though.
The image you showed would definately be created using curtain walls. So I must be missing something. The building you showed would be very quick to create, YOu would create an inplace mass the shape of the building, then create a curtain system with the panel spacing shown, and then use the curtain wall by face tool. Is it the SSG glazing thats the problem for SSG you have to modify a mullion profile and offset so it sits behind the glass.
Just change the Material for you glass not to be so transparent. Is the issue you are having when you are rendering the view or just view it with shaded with edges? If its when rendering select a glass material with a higher mirror/reflectivity and perhaps a colour. If its when shading goto settings-->materials-->glass (check to make sure this is the material being used by your curtain walls) and set the opacity to 5 or something lower. 100 is fully transparent...
Regards,
Chris.
3 Posts No Rating |
sdbrown: although what you said didnt asnwer my question it was usefull for another part of the building, so thank you. mr spot: your tips helped out, thank you. also, i was trying to focus more on fixing it wehen rendered but now i can use shading with edges pics when i show her as well. Thank you very much!! Thank you both for your help, now i can finish the project faster and focus on details.
Roof Covered Entry Problem |
Mon, Jan 31, 2011 at 1:58:30 PM
Revit glass looks flat |
Mon, Jun 14, 2010 at 5:40:09 PM
Transparency of glass windows in 3d views |
Wed, Aug 5, 2009 at 10:43:37 AM
Rendering glass with pattern 2009 |
Mon, Oct 13, 2008 at 3:27:21 PM
Controlling Fill Colour of Linked Files |
Sat, May 17, 2014 at 10:34:59 PM
