72 Users Online (70 Members):
Forums >> General Discussion >> Revit Project Management >> Problem with structural members cutting in plan
1 Posts No Rating |
We cannot figure out why our cross bracing and diagonal columns will not cut properly in plan. We've checked out view range and it's set properly and cuts everything else as it should. The cross bracing shows up in plan as if you were looking at it from above and all adjacent elements (walls, doors, etc.) cut properly at 4'. It's especially odd because these bracing members DO cut properly in the wall sections. Can anyone provdide insight into this seemingly correctable problem?
is the diagonal column in place family? if not, check the family itself and the settings for the cut view, you might need to add a field region as well..
15 Posts No Rating |
There is no way to make revit structural braces show correctly cut at 4'-0" on floor plans because the family is created on horizontal working plane. Now I have the solution. I created a vertical bracing family that show correctly cut at 4'-0" above floor level. Anyone suffering from this problem can download it. Search under my username.
1 Posts No Rating |
we are running into same problem, even using ktam object, we have the same problem. Any more ideas?
2021 Any new updates for this problem?
Just found this. so simple!
Revitize - Another Revit Blog: Structural Framing and Plan display
Edited on: Fri, Nov 5, 2021 at 2:32:32 PM
Structural link not cutting toposurface |
Thu, Mar 7, 2013 at 7:26:34 AM
Cutting Structural Framing Members with other members in Revit 2012 |
Tue, Jan 31, 2012 at 10:54:50 PM
Sloping Structural Members |
Sun, Jan 9, 2005 at 5:32:40 PM
Structural Members not showing up in any view- Revit Arch 2011 |
Thu, May 19, 2011 at 12:11:08 PM
Curved structural members?? |
Tue, Apr 6, 2010 at 11:35:56 AM
Members: | 1998310 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
