64 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Door and Windows
56 Posts No Rating |
I used a store front curtain wall for the glass front in a building. To show a door, I changed the panel type to a door panel. This door shows up in a schedule, but I cannot tag it as a door. Any suggestions? Also, for some glass panels, I used a curtain wall. is there a way to put those into a window schedule and tag it as a window? Using 9.1. Thanks
20 Posts No Rating |
You did the right thing by changing the panel into a curtain wall door panel. You can tag this door - you just have to keep hitting tab in plan to select that particular panel. Hover over the door swing in plan while in the tag command to make this easier. The easiest option is to use the "tag all not tagged" command, and select doors. As for your window issue, you can schedule curtain walls, and you can schedule windows, but you cannot schedule these two items toegether. Hope that helps. -Jen
Windows in a Garage Door (Help!) |
Tue, Jun 27, 2006 at 10:49:13 AM
Interior windows in door schedule |
Fri, Dec 12, 2008 at 12:51:23 PM
Door & Windows Schedules |
Fri, Oct 5, 2007 at 7:02:32 AM
Excluding doors and windows in count |
Wed, Feb 15, 2006 at 2:59:05 AM
Best way to show doors and windows for the door and window schedule |
Mon, Nov 9, 2009 at 7:04:47 AM
Members: | 2002700 | Objects: | 22887 | Forum Posts: | 152181 | Job Listings: | 3 |
