73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Duplicate Revision Tags
2 Posts No Rating |
We have our titleblock set up to incorporate the revision number/date/description, and it works fine, except that it repeats itself for each individual revision cloud added to the drawing. So if there are five clouds for revision 1, that tag is duplicated 5 times in the titleblock. Any ideas how to prevent this? Thanks!
Go to your sheet family and select the revision schedule in there. Edit the schedule and uncheck the box for "Itemize every instance". Save and load into the project.
2 Posts No Rating |
Thanks archdan, that did the trick!
69 Posts No Rating |
I just edit the existing cloud I want to have the same revision number and text. Then you only get one entry, but you can have many clouds
I would recomend archdan's method over Erik's. Each revision and change should be its own bubble and its own edit. If you end up making one of them under the wrong revision erik's way take more to change and make correct than does archdans.
So do I :-) I am already changing my ways
160 Posts No Rating |
active Joined Wed, Nov 10, 200482 Posts Go to your sheet family and select the revision schedule in there. Edit the schedule and uncheck the box for "Itemize every instance". Save and load into the project. First time trying to get my revision clouds working. I followed the above instruction, but tags don't update, just keep repeating the #1. Any thoughts?
Revision table mystery |
Thu, Jan 24, 2008 at 9:33:07 PM
12
Scheduling Revision Tags by Sheets |
Mon, Oct 26, 2009 at 4:43:22 PM
Hiding a Revision in the Revision Schedule |
Thu, Nov 21, 2013 at 3:04:51 PM
Revision Schedule not updating |
Tue, Aug 28, 2012 at 7:59:18 AM
Revision Cloud Line Style for Non-Revision Purposes |
Tue, Sep 7, 2010 at 1:17:17 PM
Members: | 1994028 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
