64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Line Styles
69 Posts No Rating |
I'm trying to change a model line in a family to a center linestyle. In projects you can just create new line styles but it doesn't seem to be the case in families. And on top of that, I can't just copy/paste the line from the project to the family (it says you can't copy from project to family). Any work arounds? Other info: the family visibility is set so that only this model line shows up in coarse view. Its for a structural framing plan.
You can go to Settings--> Object Styles and create a new object style, and change the linestyle in there.
14 Posts No Rating |
In a profile family, it is not possible to add/modify subcategory. How did you resolve this issue?
Jhui - Do you mean a new Line Pattern? If so go to Settings-->Line Patterns and create your new pattern. mebowles55 - You will not be able to apply the line pattern until you get the profile applied to a sweep in a project. For example you can create a Cornice Profile and in your project you can add a subcategory to walls and apply the Sweep to that category. I am not sure if this works for sweeps integrated into the wall type but I know it works for Hosted Sweeps.
Thanks. I think I got it.
Removing Line Styles |
Mon, May 8, 2017 at 2:21:04 PM
Associating Line styles with patterns |
Tue, Sep 18, 2012 at 11:30:05 AM
Deleting Line Styles |
Tue, Aug 5, 2014 at 2:57:29 PM
Line styles |
Sun, Jun 3, 2018 at 8:27:34 AM
Complex line styles |
Thu, Mar 16, 2017 at 7:37:12 AM
Members: | 1999800 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
