57 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> room tags 2008
5 Posts No Rating |
i am wondering if ther is a way to add room dimesions to room tags, Thanks TA
If you are talking about displaying length and width dimension, I don't think so. Length and width are not listed as parameters when you create a room tag family. If you must have them display you could create a shared parameter for length and width which would allow you to manually type in length/width for each room, and then you could display the shared parameter on a tag...but I don't know of any way to make those length/width dimensions automatically update as the room changes. HTH. Troy www.myCADD.com
ROOM TAGS |
Fri, Jul 29, 2011 at 8:25:58 AM
Room Tags disappeared when 08 file saved in 09! |
Wed, Sep 10, 2008 at 1:11:22 PM
Select room tags; copy rooms to new phase |
Thu, Jun 29, 2006 at 7:19:48 AM
Room Tags on Demo Plans |
Mon, May 9, 2022 at 3:23:12 PM
Want to see Room Tags but not Rooms |
Wed, Oct 5, 2016 at 11:37:51 PM
Members: | 2008066 | Objects: | 22917 | Forum Posts: | 152188 | Job Listings: | 3 |
