206 Users Online (102 Members):
- Most ever was 450 - Fri, Oct 26, 2012 at 3:27:19 PM |
Forums >> Revit Building >> Technical Support >> Double Line Room tag
69 Posts No Rating |
Does anyone know if you can create a double line room tag? If so how? Or does anyone have one they want to share?
Thanks
If you edit the room tag family and shorten the length of the label object it will wrap sooner and give you two lines. Use two room tags, one each for long and short.
Or you can create a second parameter (shared parameter) Room Name line 2 (whatever you want) and add a label that uses that parameter in the tag. This will make schedules awkward...
Thanks so much I knew it had to be something simple!
Leader line position from Room tag |
Thu, Aug 9, 2007 at 11:44:38 PM
Room tag not showing in only one room. |
Wed, Sep 19, 2012 at 5:57:56 PM
Editing a room tag |
Tue, Jun 14, 2005 at 1:32:10 PM
ROOM TAG TAGS ONLY HALF OF THE ROOM |
Mon, Jan 14, 2013 at 6:06:45 AM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 12:52:40 PM
Members: | 405154 | Objects: | 14156 | Forum Posts: | 118414 | Job Listings: | 6 |
