Forums >> Revit Systems >> Technical Support >> Revit and IES Virtual Environment
I was wondering if someone has any experience in using the Virtual Environment for light simulations etc. Our company is really intrested in using this software but we would like to hear opinion from someone that uses it in his work. Dawid
21 Posts No Rating |
As a stand-alone product IES-VE has all sorts of add-on packages that can get as detailed as you need to be. This may be what you need, and perhaps you can import your Revit model into IES to what you need. IES can generate some fantastic renderings fast, and the software has glare calculations that will alert you when window glazing shading and coefficients are unsatisfactory.
I have been using VE for a while in conjunction with Revit. Solid program, easy to use, better that e-quest. as far as lighting goes that is where i started. very useful since revit only give you a zonal cavity calculation. i attached a generic room i did with some cooper lights it took me about 5 min to set up and another 5 to run the calc on medium. as far as the life cycle cost analysis, thats where the fun begins
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/ |
It might have helped if i grabbed the right image.
6 Posts No Rating |
is Eddieboarder91 in? i just want to get more details about IESVE coorperated with revit MEP in artifical lighting analyse. 1. can i only import gbxml files from revit into IESEV? are ther any other ways? 2.when i import a revit model into IESVE,can the lighting fixtures be imported into IES and have their properties? if not what should i do? i am looking forward to your reply. thank you very much!
spritelxx, If you have a seat of Revit MEP, there is a direct link (Click on the Mechanical Tab -> Heating and Cooling Loads), I know IES has been working on Revit Architecture for a solution, currently they have a API plug in. But I am unsure if there is a direct link. Were really going to open a whole new can of beans with this one. To import a Lighting Fixture into IES <VE> you have to import the *.ies file. From this, if the Lumcat parameter is populated it will bring it in. Unfortunately you are unable to import Revit families into IES <VE>. Yet anyway. To seperate these IES <VE> = Intergrated Environmental Solutions <Virtual Environment> *.ies = Illuminating Engineering Society <- Photometric data, may look like gibberish, but there are patterns and a method to this madness, I do not suggesting looking very hard, it comes with time. If all you are looking to do is interior artificial lighting, check our a program called Dialux, it is a european program but very very simplistic and easy to use. HTH
6 Posts No Rating |
Eddieboarder91, thank you very much! i do not know what you mean by"To import a Lighting Fixture into IES <VE> you have to import the *.ies file." can revit create a *.ies file,or anyway through revit? I have been using dialux for just a little while,not very good at it.it can not import revit model.if i recreate a model,the work must be hard.i am a student now,studying a method of lighting design based on BIM,the most important thing is to achieve the information exchange without rework. in my opinion,the revit mep is a good tool for mep design.so i try my best to get another tool to go along with it.i really appriciate you for more details. best wishes
Revit Architecture 2009 and Revit MEP 2009 now support IES data. You can import them in for renderings and have read that the information gets exported as well. The IES data is in the lighting fixture family.
6 Posts No Rating |
thank you, twometer. do you mean that i can create a building model with lighting fixtures in revit mep 2009 ,and then export it into IESVE directly.meanwhile the lighting fixtures are active and have its properties for analyzing. if so,that would be a great news for me.
Have not tried it personally, but this is what the help file in Revit MEP says... "Revit MEP incorporates photometric data for lighting fixtures using an industry-standard format in Illuminating Engineering Society (.ies) files. The data describes the intensity and distribution of light that is used for lighting analysis. This manufacturer’s data is now included with the information exported to IES<VE> when you export the building model." Might work from Revit Architecture as well.
6 Posts No Rating |
i really appreciate you for your help.i am downloading the revit mep 2009. best wishes!
In responce to dialux, it is a very very very simple program, yes you have to recreate the model, you do in ecotect too. you are right about the theory of bim, that it SHOULD be interoperable with other programs, what is happening though and you now know this is everything is not BIM. Revit MEP is a good design solution, but it is only a tool, you still have to understand what you are doing. what school are you learning this at? you could associate the ies files in 2008 too, what has happened, and i am glad it has is that autodesk got smart is starting to get away from externally referenced data (ie. IES files, Look up tables). When you are working with 2009 you will see a major difference in the Lighting fixture family, you have the ability to add much much more information in an easier way, of course you need to know this information which for most lighting manufactures they do not provide. FYI: the link between 2009 and ies, works, there is still some manipulation, still dont know if works in arch 2009, it is not as easy and transfer and go. I beta tested mep 2009, the thing is, it will only work with IES <VE> v5.8.5.2 (I think, I am not at my machine right now).
6 Posts No Rating |
Eddieboarder91, thank you.i am a Chinese student.i have gotten revit mep 2009 and have a try.i lost my password a few days ago.
Does anyone know how to control the render environment? Can it be manipulated and customized? The factoryl environment doesn't cut it, especially for exterior renderings. If anyone has any know how, please share.... Thank you,
id use max as would most other people on this site...it runs much faster and gives a better product...if you dont have it available try checking out augi for suggestions i know they are out there just a bit to tired to go find them again...
IES files in Revit |
Mon, Feb 6, 2017 at 4:00:14 PM
SketchUp and IES |
Fri, Aug 29, 2008 at 1:18:34 PM
Virtual Environment VS. Ecotect |
Mon, May 25, 2009 at 10:18:54 AM
lighting analyse with IES |
Mon, Apr 28, 2008 at 1:56:56 AM
IES Photometric lighting issue - no light |
Thu, Aug 13, 2009 at 3:30:28 PM
Members: | 1998011 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
