62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Visible floor lines??
4 Posts No Rating |
Can someone tell me how to turn-off the horizontal lines of the floor structure, when viewing the exterior elevation of a 2-story house. They are visible from the exterior elevations & 3D view. Thank you CND
In Visibility/Graphics, uncheck the floor catagory.
4 Posts No Rating |
Thank you for the tip. I tried this before, and the entire floor disappeared (and was unable to see the balcony floor) I will check again to see if I missed something. Thank you much. CND
If you need to see some floor slabs, then you will have to leave floors turned on. If it is only a few lines in your elevation that you dont want to see you can use the linework tool to make them invisible.
Draw the floor so it lines up with the inside or middle of your wall. This way you won't have to turn anything off. I know this is not the correct way to build the floor but The only area that you will see the floor is in a section and that can be redrawn using 2d elements.
Macca Sunshine Coast QLD Australia |
4 Posts No Rating |
Puzzle At this time, this seems to be the most appropiate solution. Although I would need to adjust my sections to read correctly (platform framing used). Thanks just the same.
If you use the paint tool you can paint the edge of the slab the same as the wall material. Then use join geometry with the walls and the lines will clean up.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
4 Posts No Rating |
Mr. Spot. This is a wonderful solution. I cant wait to try it out. I will let you know. Thank you very much. CND
drawing lines over a tike floor |
Mon, Mar 30, 2009 at 5:21:15 PM
Hide door swings which are visible from floor below |
Wed, May 6, 2015 at 12:16:03 PM
Stair visible through floor |
Thu, Feb 5, 2009 at 5:21:21 PM
Floor Slab not visible in Plan! |
Tue, Nov 9, 2010 at 1:58:17 PM
Walls and floors not showing up on other levels |
Sun, Feb 17, 2013 at 5:39:01 AM
Members: | 2002178 | Objects: | 22887 | Forum Posts: | 152181 | Job Listings: | 3 |
