73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Nested Families....
7 Posts No Rating |
Hello, I am somewhat new toRevit and I am wondering if there is a way to Tag and schedule nested families. I am trying to develop a very detailed Revit model that requires modeling as much as bolts. We also want to keep track of everything... bolts etc... SO, we would ideally make a bolt family, import it into another family (beam or something), then import the beam family into an assembly family, then finally load it into the project family. I can do all of that, but if I tag the assembly in the project I only see the parameters of the top level. Is there anyway to see the nested family's parameters? Or in schedule them? Thanks.
Nested families will tag if they are set up to share.
7 Posts No Rating |
Can you point me in a direction to make a family 'share'. -Tom
As you build each family, look munder the settings pulldown / family category and parameters.
7 Posts No Rating |
Thank you very much!
Locking nested families? |
Wed, Aug 27, 2008 at 12:23:09 PM
13
nested families do not cut |
Thu, Jan 14, 2010 at 11:44:55 AM
Door swings with nested families |
Fri, Sep 18, 2009 at 1:41:24 PM
Hiding nested families in a project |
Thu, Jan 14, 2010 at 10:21:37 AM
turning on/off nested families in host family in different views in project. |
Fri, Aug 7, 2009 at 11:11:32 AM
Members: | 1986970 | Objects: | 22874 | Forum Posts: | 152182 | Job Listings: | 3 |
