Forums >> Revit Building >> Technical Support >> Insertion point?
Fri, Mar 30, 2007 at 5:34:36 AM | Insertion point?
nirim
5 Stars: 12 Votes
Hi there
May be it is obvious but not to me, how can I find the insertion point of a building that I been inserted in to site layout plan as ‘x-ref’?
 And how do I remove the link between elements? (When I want to move one wall all the wall and floor that connect to it move as well)
thanks Nirim
Fri, Mar 30, 2007 at 3:28:07 PM | Insertion point?
rkitect
rkitect Avatar
4 Stars: 29 Votes
What is this "x-ref" you speak of? There is no such thing in Revit. Only Links :D
I'm not sure about finding an insertion point, but you can share the coordinates of the file you linked in with the building project (called Shared Positioning) as shown in Steve's blog entry here
To remove attachments that walls have when moving, click the disjoin radio button in the options bar when you use the move command.
This will ensure that nothing follows it. You can use this on more than just walls.
Edited on: Fri, Mar 30, 2007 at 3:28:14 PM
Edited on: Fri, Mar 30, 2007 at 3:30:47 PM
Mon, Apr 2, 2007 at 3:00:33 AM | Insertion point?
nirim
5 Stars: 12 Votes
rkitect
Thanks for the information; I probably need to learn little bit more about share coordination, however I did not mean x-ref literally I did  not know how to describe the situation.
nirim
Mon, Apr 2, 2007 at 7:43:09 AM | Insertion point?
rkitect
rkitect Avatar
4 Stars: 29 Votes
I figured Smile.  I just like to pick on people that use AutoCAD terms to describe Revit situations Winking
No harm meant.
Export insertion point???
Thu, May 4, 2006 at 2:31:08 AM
Insertion Point of Custom Titleblocks / Title Blocks
Tue, Oct 13, 2009 at 2:57:30 PM
Insertion point - families
Thu, Dec 3, 2009 at 7:21:52 AM
Tag Leader Origins
Thu, Mar 17, 2005 at 12:45:31 AM
Revit Export Block Insertion Points
Fri, Oct 2, 2009 at 2:16:39 AM
Page generation time: 0.1983
