88 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> Wall Tags not unique for stacked walls
1 Posts No Rating |
Hi all,
I have same problem.
What I want is tagging stacked wall on Wall finish plan, and schedule what I have tagged.
I tried to use Project Shared parameter, but it works not very well.
Please help me to find another solutions.
Thanks all.
Edited on: Mon, Feb 24, 2014 at 10:51:19 PM
Edited on: Tue, Feb 25, 2014 at 2:53:24 AM
A stacked wall can not be tagged as one. It is a stack of walls....each can be tagged by their own type.
0 Posts No Rating |
I have a solution for you all.
I have 2 wall types for relatively identical walls. Wall Type A is a Load Bearing Wall and has heavier guage steel studs, and Wall Type B is Non-Load Bearing. Both walls are stacked walls; Efis above Stone.
In order to get wall tags A & B to display correctly:
- first I duplicated the stacked wall, and named the two Identical stacked wall types "Efis above Stone - A", and "Efis above Stone - B".
- Next I noticed that the wall tags are tagging the wall which the plans view range is cutting through, this being the upper wall of the stacked wall, I went to my walls and duplicated the Efis Wall and named the two "Efis - A", and "Efis - B"
- Go into the properties of wall type B and change the Type Mark to "B".
- Now assign the new uppper wall types, A & B to their respective stacked walls A & B.
This solved my wall tagging issues with stacked walls, especially since they were just duplicates of eachother, and the only differnce beiing in how I notate, and detail them in other views, but the wall tags now work correctly.
Please reply if you that wasn't clear enough, or you need a visual, I can create a screencast if needed.
Wall Tags not unique and not working correctly |
Thu, Mar 29, 2007 at 2:37:09 PM
Scheduling of Stacked Walls |
Tue, Aug 18, 2009 at 2:16:01 PM
stacked wall troubles |
Tue, Feb 13, 2007 at 2:47:36 PM
stacked walls |
Mon, Sep 10, 2018 at 9:55:14 AM
Temporary dimensions and stacked walls |
Wed, Feb 9, 2011 at 8:47:10 AM
Members: | 1996474 | Objects: | 22885 | Forum Posts: | 152185 | Job Listings: | 3 |
