106 Users Online (105 Members):
Forums >> Revit Building >> Technical Support >> Geo-Mapping textures
43 Posts No Rating |
On a similar vein as the previous question, is it possible to map an aerial image onto a topographical surface (one with variation, not flat)? I can do this in GIS programs, but have not been successful in many of the 3-D programs, because they often do not know how to translate depth information from a raster image onto planar surfaces, and have not figured out a way to import a topo surface with the mapping attached.
This is a very nice technique for giving realism to a topographic surface, and would be wonderful to have in Revit.
Hmm,
If you only want it to display when rendered (as this is the only way i can think of doing it) you may be able to setup a accurender material using the image as a map, then scale to the appropriate size and set this as your topographical material.
I was able to bring an aerial image in and apply it to a surface as a material, but it is applied as the mirror image of what I need. Is there any ideas on how to mirror it back to normal?
Mapping faces |
Mon, Mar 5, 2012 at 1:55:20 PM
Geo-Referencing |
Sun, Dec 5, 2010 at 5:42:29 PM
Linking CAD file with GEO Marker - RAC 2010 |
Wed, Sep 23, 2009 at 4:58:21 PM
free hi res textures |
Mon, Apr 13, 2009 at 2:47:29 AM
Make pattern&mapping bend |
Wed, Oct 30, 2013 at 9:06:10 AM
Members: | 1998395 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
