78 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> NEW Gyp on EXISTING Stud wall
Looking to see how other people do this. I have existing 6" walls that are studs only and I'm trying to find the best way to add gyp board to each side of the wall in the New Construction Phase. Just looking for opinions here. Thanks!
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
you could create a wall as 'drywall' only. then draw it as new construction.
Thought about that. The only consequence I could think of for that would be the overlapping walls warning. and then having wall based families only cutting one of those walls (ie: door, window, opening, etc.)
15 Posts No Rating |
couldnt you then just join the two walls and the door/window/opening would then cut both. (excuse me if I'm wrong.)
that's right; draw the wall next to the other, join, a wall-based item should cut threough both. Walls should not overlap. Make sure your loc line is set right.
yessssssss
I see.. you were suggesting a single 1/2" wall (for gyp) next to the existing wall. That makes sense and would probably work well. Thanks for the suggestion.
Stud Wall-Make finishes disappear |
Fri, Jan 30, 2009 at 5:24:09 PM
Wall Footings |
Tue, Dec 15, 2009 at 2:16:22 PM
How are you all naming wall types |
Thu, Oct 11, 2007 at 2:24:37 PM
Renovation Wall Suggestions |
Wed, May 23, 2007 at 8:23:18 AM
Revit 2012 - Where have my stud wall lines dissappeared to? |
Thu, May 3, 2012 at 12:57:17 PM
Members: | 1991523 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
