85 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Windows Vista
Thu, Jun 21, 2007 at 1:27:07 PM | Windows Vista
#16
broncos4life
4 Stars: 10 Votes
Revit will run on both 64 bit vista and 32 bit vista.  With 64 bit you just need to tell your OS to run Revit as a 32 bit program.
Thu, Jun 21, 2007 at 1:53:51 PM | Windows Vista
#17
vart41
I got two computers with windows vista home basic running revit 9.1.. runing as administrator work fine, but i still have trouble with the elevation views.  if i try to save staying in one leveation view my revit crash inmediately.  Any advices?
Sat, Jun 23, 2007 at 7:34:23 AM | Windows Vista
#18
Ace001
OK, Revit 2008 works on  Vista Ultimate 64.  It seems faster Probably because  the Os background operations are running fester. Revit still runs at 32 bit.
I'm running a dual core AMD Opteron64 2.2ghz overclocked to 2.7Ghz with 2gb ram and an Ati Radeon x1900
I should get more ram 'cause it runs at 75% most of the time, but i'm thinking of rebuilding the whole rig.
Fri, Jul 6, 2007 at 8:27:09 PM | Windows Vista
#19
rkitect
rkitect Avatar
4 Stars: 29 Votes
The only time I hit 75% with Revit running is if I'm running two instances of revit and rendering a scene in Maya at the same time.  I wonder if it's a matter of running the 32 bit operation on a native 32bit OS.
Tue, Oct 30, 2007 at 4:36:15 AM | Windows Vista
#20
abulin
abulin Avatar
Another Fate tempter here Puh
Vista Ultimate 64bit
AMD Athlon 64 X2 Dual 6000 (3.0ghz)
ASUS SLI Vista Premium MoBoard
2gb ram
nvidia GeForce 7950 GT
Revit runs beautifully!  I did not even have to jump any hoops or shut anything down.
I have the Architecture Suite version, and the AutoCAD, however is behaving badly. heh.
In fact, I am just now finishing my OS re-installation number 2!!!
Oh well.  I'm tired of CAD anyhow!  :D
Thu, Jan 24, 2008 at 10:38:36 AM | Windows Vista
#21
charlotte240
charlotte240 Avatar
3.5 Stars: 3 Votes
Someone please tell me what is the point of running windows Vista in 32 bit?  Does Revit not work as a 64 bit program?  AUGI forum has a guideline that says Revit wil run best on 64 bit machines.Am I missing something?sorry, I am an architect, not a comp whiz...thank you,-m
CRI
Wed, Feb 27, 2008 at 7:10:20 AM | Windows Vista
#22
abbeydesign
I have tried all the tricks in this forum and still have no luck running Revit 9.1 in Windos Vista Home Premium 6.00.6000 in 32 bit mode.
Do I need a different version of Revit 9.1 or of Vista?
Mon, Apr 21, 2008 at 9:09:01 PM | Windows Vista
#23
abulin
abulin Avatar
hey guys.
im running vista64 ultimate and revit architecture 2008 build: 20070324_1700 with no problems thus far.just about finished with all the white papers.
about to dive right into a mock project for the first time!!!
im so excited!  but as far as vista goes, im very satisfied with my setup and have very little problems.
Sun, Jun 8, 2008 at 3:04:09 AM | Windows Vista
#24
Andreea
Not only does Revit run on Vista64 but it runs flawlessly. It was actually the reason i gave up on XP.On XP  Revit2009 crashed all the time (think 3-4 times/day). On Vista64 it has yet to crash once. Fast, stable, robust performance.
Regarding compatibily, i'm running AutoCAD LT 2006 on the same rig without any issues and without using any patch. Just tweak the Compatibility tab and check the "run as administrator" option.
Overall, nowadays i'm a believer : i can't imagine going back to XP.
Sun, Jun 8, 2008 at 3:14:12 AM | Windows Vista
#25
abbeydesign
I would get Revit 2008 because the problems that earlier versions cause make the wole process a nightmare.
 It is possible to get early versions of Revit 9.0 to work by following the guidelines in this thread, but 9.1 won't work and AutoDesk aren't bothered because they want you to buy 2008 / 2009 versions anyway.
Sat, Jul 12, 2008 at 6:45:51 PM | Windows Vista
#26
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
Working on Vista Ultimate x64 with no problems at all.
System:
Intel Core 2 Quad Q6600 G0 @ 3.0ghz | ABIT IP35 Pro | G.Skill 8GB DDR2 1000 (PC2 8000)| EVGA 8800GTS 512 G92 | Corsair 620HX | Vista Ultimate x64
Thu, Sep 18, 2008 at 7:33:50 AM | Windows Vista
#27
tim123
4 Stars: 19 Votes
Revit works in any weather, but if it is raining you need to come inside.  This is usually not to do with Revit, but is a hardware problem, as many computers struggle with excessive moisture.  I also find it difficult to work when it is too windy.
Revit also works with Vista.
Sun, Nov 28, 2010 at 5:51:50 PM | Windows Vista
#28
Diegoivan
Hi I have Windows Vista in my laptop and I have Revit, Autocad and Inventor from Autodesk and everything works very good.
Have a great day !
Does Revit 2009/2010 work properly to on Windows 7
Thu, Jun 3, 2010 at 4:25:04 AM
12
Revit 2011 Network Drives Disconecting for Windows Vista
Tue, Sep 21, 2010 at 2:05:39 PM
Revit and Windows Vista Beta
Fri, Nov 17, 2006 at 11:11:36 AM
User Material file Location in Vista
Wed, Sep 23, 2009 at 11:23:50 PM
HP DESIGN JET 1050C FOR VISTA 64 BIT
Fri, Apr 18, 2008 at 6:39:35 PM
Page generation time: 0.3034
