162 Users Online (159 Members):
Forums >> Revit Building >> Technical Support >> Wall Schedule
2 Posts No Rating |
I am working on a fairly in depth wall schedule for a project. I would like to be able to schedule rough areas for sheathing, siding or other exterior finishes, and drywall takeoffs, etc. For our purposes, I am basing everything on the wall area, which Revit calculates already, and using that as the basis for a formula. An example of the issue is calculating drywall area. Interior walls have two sides of drywall, while exterior walls only have one side of drywall. In the end I need a total drywall square footage number. The problem I am running into is that Revit seems to only let you 'calculate values' by column, whereas I need it by row. Is there a way to assign a different formula to each different cell as you can in Excel?
Have you tried using the Material Takeoff schedule in Revit 9.1? The Materail Takeoff schedule will get the areas and volumes of the mutliple layers the wall is composed of. Be sure to do some simple sample work to be sure you understand how Revit treats things like door and window openings as they relate to material areas.
Tom www.reviteer.com http://twitter.com/Reviteer |
Quick Wall Schedule Question? |
Tue, Oct 21, 2008 at 12:40:21 PM
Storefront schedule: wall length changes |
Mon, Jun 6, 2011 at 12:44:46 PM
Wall Area Schedule |
Mon, Sep 19, 2011 at 3:44:22 PM
Embedded window schedule in Room schedule |
Thu, Nov 19, 2015 at 1:03:49 AM
Schedule of structure of wall |
Wed, May 19, 2010 at 1:39:45 AM
Members: | 1977072 | Objects: | 22860 | Forum Posts: | 152166 | Job Listings: | 3 |
