76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> rotate text not
17 Posts No Rating |
I have created some text in a file, then linked that file to another and rotated it. the text has rotated as well, which means it no longer fits nicely any way that i can keep the text parallel to the original file, instead of it all rotating to the new page?
Any luck? I have the same issue. I have a north arrow that I would like the "N" to be stationary but have the arrow rotate.
i suggest putting the test in a location so that when in the end result everything will rotate, but the apperance will be correct. as for the north arrow, if it is a family, go into the family file and rotate the arrow itself and not the text. save and reload the north arrow in to project.
----------------------------------- PWD |
I was looking for more of a parametric way of rotating the north arrow. I guess I could set up an on/off parameter and use up/down/left/right. Just thinking out loud
definatly, you could do that, was just trying to give a easy fix. if you understand families then absolutly set it up as a family that is parametric. it will fit more situations that way as well as save time.
stuck button
Not sure why those posts keep posting.
Rotating Family Text |
Wed, May 7, 2014 at 5:04:06 PM
Rotating the view Port but not the text |
Tue, Apr 9, 2024 at 8:10:46 AM
Text in Section tags rotating |
Fri, Mar 2, 2007 at 9:12:13 AM
Rotate dimension |
Wed, May 28, 2008 at 2:39:48 PM
ROTATE ELEMENT |
Mon, May 16, 2011 at 8:15:08 AM
Members: | 1992019 | Objects: | 22879 | Forum Posts: | 152183 | Job Listings: | 3 |
