115 Users Online (115 Members):
Forums >> Revit Building >> Technical Support >> Adding SIM / TYP to Detail View Callouts
11 Posts No Rating |
What was the fix?? I'm having the same problem!!
Read this: http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-E0178807-4718-4C5F-9A22-0DF5673F2C69
Then tell us what you have done.
Edited on: Mon, May 5, 2014 at 3:26:33 PM
31 Posts No Rating |
WWHub I have ran into the same problem the rest have had. Let me see if I can explain it in a different way.
I have created a drafting view detail and have referenced it about six times in the project (I have not needed a Reference Label with this six). The problems come into play with the seventh time I reference this same detail because it does need the Reference Label. I have duplicated the original head and added Sim to the Reference Label (works great). The problem is that now the first six callouts I placed now also have the Sim text. If I change them back to the callout without the Reference Label then they all change even the one I want to have the text.
I have callouts say Sim and ones which do not in the project. All of them are working fine. I am only running into this problem when referring to a single detail view and wanting some of them so have a Reference Label and some to not.
From what I have read this is not possible but just wanted to check again since this is an old post. I am using rvt 14
Thank for your help,
smh
I think your only solution will be to add SIM as text in the callout location. This function does not seem to work as you want.
SIM OPP TYP |
Sat, Sep 17, 2005 at 10:41:00 PM
Callouts and Callout Sim Views |
Thu, Sep 12, 2013 at 10:41:57 AM
callouts and detail views |
Tue, Jun 17, 2008 at 3:45:53 PM
callouts with "typ" label? |
Mon, Sep 15, 2008 at 1:44:41 PM
multiple section callouts |
Wed, Jun 4, 2008 at 9:04:18 AM
Members: | 1993378 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
