44 Users Online (42 Members):
Forums >> Revit Structure >> Technical Support >> Toposurface Volume
1 Posts No Rating |
Is there any way to add volume to a toposurface, so that when displayed in 3D view it doesn´t show up just like a hollow floating mesh, but rather than a closed volume with "walls" or planes following the suface borders like the ones generated when a Pad cuts the terrain?
To my knowledge, no. You can however (if you really need a solid floating mesh as opposed to a thin floating mesh) make points just outside of the border of you toposurface that are relatively lower than the border (say -250' or so) If you find something otherwise, let us know!
Creating a wall tag with a volume parameter |
Sun, Jun 23, 2013 at 3:56:03 PM
Topography - Cut and Fill for Graded Region |
Thu, Feb 3, 2011 at 12:49:41 AM
Calculating Volume |
Tue, Sep 4, 2007 at 2:35:09 AM
Taking off material volume |
Wed, Feb 22, 2012 at 4:08:50 AM
conc volume |
Mon, Apr 11, 2011 at 9:21:01 AM
